Anyone here changed a 55 Chev 4dr into 2dr ?
Discussion in 'The Hokey Ass Message Board' started by Steel Coupes, Dec 8, 2007.
  1. Steel Coupes
    Steel Coupes
    from Midwest
    Or really any or the tri-5's. But I'm more interested in a 55. Just wondered if anyone here has actually done one. Or might know where some pics of someone doing it, or even someone describing it. There's a ton more nice cond. & reasonably priced 4drs out there to start from than rotted out real hardtops & sedans.
  2. wyoming
    wyoming
    from My house
    search the tech archives for a post by squablow ,i think, he did this with an old plymouth
  3. JamesG
    JamesG
    I think someone just did one with a 55 Chevy.
  4. CSU55Chevy
    CSU55Chevy
    from Olathe, CO
  5. daddylama
    daddylama
    use to have a neighbor in Northridge who was doin' it to a '57 chevy... last i saw, it was coming out very nicely, but it had been a long-term project.
    he took an overhead projector (like the kind in school), with a side-view tracing of a '57, and shined it upon the 4 door... lined everything up, drew out his cut lines and such...
  6. redlinetoys
    redlinetoys
    from Midwest
    There are a couple of posts on www.chevytalk.com regarding the conversion. I don't remember the specific post name to help you search, but you could find it there if you try hard enough.
    Also, I believe one of the guys actually only converted one side and left the other side a 4 door version, effectively turning the car into a 3 door. Not sure why you would want to do that but it was interesting.
    Frankly, I would think it would be a whole lot easier to just pick up a two door body in the first place, but I know one of the guys just had a car that was well done and had some sentimental value so he added the conversion.
    There is a 56 four door on that side that is really pretty nice as a 4 door. I think a more door can look good too...
  7. Old School 40
    Old School 40
    30 year do it for a living bodyman says SPECIALIZE for the guy who cant live with the four door
  8. low budget
    low budget
    from Central Ky
    How bout a 4 door hard top 55 ? ever seen this coversion?
  9. jonzcustomshop
    jonzcustomshop
    that 4 dr hdtp looks cool.. is it yours?
    About 15 years ago dad and I bought a 56 canadian pontiac 4d hdtp to do this conversion.. It has been on the back burner for long time......
    We were going to go about the side chrome differently though, we are going to use a door divider off a 55 wagon , and two tone it - body one color, roof - the other, like a belaire wagon.
  10. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I used to have a 55 Olds 4 dr ht, I always thought of doing the 2 dr conversion if I got it back...but the roof and back window are way different than that of a 2 dr ht. Might look awkward.
  11. redlinetoys
    redlinetoys
    from Midwest
    The idea could go a lot of different directions. A lot of people don't realize how many different body styles there were in Tri-Five Chevs, not to mention Pontiacs, Olds, etc. There were over 60 distinctly different models of the three years of Chevys.
    While many of the parts interchange, many of the pieces parts are no where near interchangeable. For example, a lot of people don't realize that a sport coupe hardtop roof is almost 2 inches lower than a sedan and uses much shorter glass...
    The blue four door hardtop above is interesting because I believe GM only made a 56 and 57 4 door hardtop. And so it would appear that someone took a 56 and put the 55 front and rear, along with side trim on the car (and of course quarter panels, etc, etc). Quite a bit of work, but it would make a unique car.
    I would think any kind of conversion would be MUCH easier if you already had a 4 door SEDAN and wanted to make a 2 door SEDAN. THAT conversion would be relatively easy if you had access to various 2 door body parts...
    A HARDTOP conversion from a 4 door to a 2 door would be a ridiculous amount of work. Any conversion from sedan to hardtop or hardtop to sedan would make even less sense.
    None of this is even taking into consideration the lack of availability and subsequent cost of stainless window trim, etc.
    My two cents for what it is worth.
    Here are some interesting websites that show the various body styles that were available.
    http://55classicchevy.com/body-styles.html
    http://56classicchevy.com/body-styles.html
    http://57classicchevy.com/body-styles.html
    Even though these websites show what is supposed to be the complete listing of body styles, they are leaving out solid side sedan deliveries and the even rarer special order cars like sedan deliveries with windows (yes, believe it or not, they made and sold them...)
    I know this is all slightly off topic, but if you are really considering the conversion and aren't aware of these issues, you might want to do some homework (or you might just decide that a reasonable cost 4 door can be cool too).
    Good luck.
  12. low budget
    low budget
    from Central Ky
    Were gettin side tracked here a little but here is another interesting 55 alteration.
  13. jonzcustomshop
    jonzcustomshop
    that 55 4dr hdtp conversion would be hard to do using a 56, since the rockers and rear door/ wheel wells would have to change along with the rear 1/4ers.
    That is why we chose a canadian 56 pontiac. Same rear wheel wells, and rockers as a 55, all we have to do is change over the rear 1/4ers , the dash, and bolt on a 55 front clip.
    to get back on topic though.... we changed over a rusty- shot up 55 conv. on to a 4 dr sedan cowl , floor pan and frame.
    It was actually a pretty smooth conversion.
    there was a spot on the front roof post dog leg where the factory welded them together. ( the basic cowl and dash are the same.)
    drilled out the spot welds on the center door post, and the same with the conv.
    then in the back we split the 1/4 ers along the factory seam under/and over the taillight.
    then we saved the rear seat braces, and acouple body mounts that were conv. specific, and we were in business.
  14. screwball
    screwball
    do a search for koolkemp he has done this at least once
  15. seventeenseconds
    seventeenseconds
    I know this is an old thread, but I would LOVE to see more pictures of this car.
  16. Mr Haney
    Mr Haney
    try explaining to the prick bastard STATE TROOPER that just got dumped by his best gal........Honest mr officer "SIR" it's really a 4-door as he hooks the fucker.......OUCH
  17. So-Cal Tex on the HAMB is in the middle of a 55 transformation. I saw it last week.
  18. KidAgain
    KidAgain
    Definitely seen this one. The guy started with a 4 door 210 and pulled some metal from a 4 door hardtop 56. Turned out pretty cool. I think I saw on the web somewhere. But beleive its been done more than once.:)
  19. rd martin
    rd martin
    from indiana
    i was at goodguys in charlotte in 03, and there was a guy there advertising with a 4dr. 55 there and he converted it to 2dr. it really looked good! nice lines, and if i remember rt. he was doing it for 2000.00 with the parts!! ready for paint!
  20. fat141
    fat141
    Do a search on this one. Same rules apply 4 to 2-door conversion on a 52 chevy, with pics !
    Good luck
  21. cretin
    cretin
  22. Savannah Red
    Savannah Red
    Saw one at a show several years ago, was walking by with my son, & saw
    this clean 4door 55, as i walked I noticed the license plate says " WASA4DR"
    as I got to the drivers side of the car, that side was in primer & was now a
    "TWO DOOR SEDAN". The Owner had some pic's laying on the dash of the
    actual conversion. It was the neatest !!!! I'm sorry I didn't bring the camera!!
    Thanks, for the Memory!!!:D
