Anyone here into large scale (1/8) car models???
Discussion in 'The Antiquated' started by Deuces, Dec 10, 2010.
  1. Ebert
    Ebert
    from Keller, TX
    Cats? I'm gone.
  2. oldschool55
    oldschool55
    Sonny, just saw your models for the first time. WOW, what can I say but, I'm blown away.
  3. Deuces
    Deuces
  4. b-bop
    b-bop
    Here is my Deuce that has been in a box for about 10 years. Sorry about the **** pictures. Comes with scale size dust on the body. You can tell it was done a while back when tweed interiors were in.
    Deuces likes this.
  5. Deuces
    Deuces
    Very cool build!! Thanks for posting the pics!! :)
  6. Deuces
    Deuces
  7. c-10 simplex
    c-10 simplex
    Not really into models---until now; i'd like to make a small mock-up of my next full size project.
    Can you give me any tips as far as making a tube frame? i'm thinking of using like fuel line tubing, which is, i think 3/8".
    Would "real" welding have to be used? Also, do they make tubing notchers that small?
  8. BIG-JIM
    BIG-JIM
    from CT
    A lot of the guy's use br***. Available at most hobby stores and even some hardware stores. Usually soldering works best. Tubing notcher?? You got me on that one. I would just get a file & file a notch. Try this for the metal http://www.ksmetals.com/
  9. breeder
    breeder
    Just sold all mine on here a couple weeks ago! Damn wife thinks we need water and lights! Sooo selfish! Lol
  10. c-10 simplex
    c-10 simplex
    OK, great; No as far as bending the br*** tubing..........? Can this/should this be done by hand or are there special tools for this?
  11. RAT "T"
    RAT "T"
    k&s makes benders, but long springs with a close id will work too
  12. whodaky
    whodaky
    from Aust
    Here are a few current images of progress on the 1/8th resin tudor body. Still a long way to go.
    Geoff aka whodaky
    [​IMG][​IMG]
    [​IMG][​IMG]
    Deuces likes this.
  13. Ah Ha!! Making tube frames, my favorite past time in model building.
    Yes the K&S Tubing (And other brands) is your best bet.
    You can buy tube cutters, K&S make one that cuts through the tube with a wheel as you tighten the tube up between it and a clamp while twisting the tube. Problem with that is it leaves a 'chamfer' in the end of the tube.
    Benders (Both like the ones you get for brake lines and the 'spring' type) I think they are both useless.
    The best way to bend tube I have found is to make your own bender, a cheapo wood cutting board and a few short lengths of tube. Drill 3 holes in a small triangle shape, glue your lengths of br*** tube into the holes and you have a bending jig. I have 3 with different distances between the triangle sides (On the one board).
    It can help to put a smaller size tube inside the one you want bent to eliminate the inside radious from kinking in.
    As for cutting? NOTHING beats the good old dremel with a cut off wheel, they are also the best thing for notching the tube.
    You can make anything.
    Just to show scale is no issue, the above ch***is is 1/32 scale, about 4inches long, this is it under the car.
    Doc.
  14. aerocolor
    aerocolor
    from dayton
    Wow! Some of these models are amazing in detail. I don`t think I see well enough to do that small stuff anymore.
    Did do some 1/4 scale Nascar stuff a few years ago but they were approaching real car cost status to stay compe***ive so stopped before I was in too deep. They were fast for big model cars.
    26 cc gas with fully adjustable suspension. The base ch***is was around $1200.00
  15. Deuces
    Deuces
    Wow! This is all fantastic stuff!! Thanks guys for posting these pictures!! :)
  16. 61falconwagon
    61falconwagon
    just finished this 1/8 scale beast
  17. Deuces
    Deuces
    That's a cool coupe!!! :D Here's a couple of kits I'm sitting on... One is the 1963 release of the Monogram 1/8 scale "Big T" and the other, a 1/6 scale AMT 283 Fuelie motor from the '90's...
  18. Deuces
    Deuces
    That Fuelie motor is a 300+ pc. set.. Kinda like the real thing.. crank, rods pistons wrist pins, cam, valves, springs, rocker arms,... Etc..
  19. A work bench diorama??;)
  20. Deuces
    Deuces
  21. big duece
    big duece
    from kansas
  22. Ace'sSpeedshop
    Ace'sSpeedshop
    from Washington
    I have two 1/6 scale rc 41 willys coupes and the wcc 54 chevy that I am working on now.he other willys im going to go for more of a led sled im going to make skirts for it and the 54. More pics as the progress comes.
    Deuces likes this.
  23. Deuces
    Deuces
    I think I posted pics of my 1/6 RC Willys on this thread??? Here's what it looked like right out of box and what it looks like gutted out..
  24. [​IMG]
    Just had this dropped in to me. Its for my big 32 that i showed at the start of this thread.
    Pretty happy about that.
    Deuces likes this.
  25. Mojo
    Mojo
    I've considered turning my 1/6th scale willys into a computer case. It's hard to find any performance motherboards that are the shorter formfactor though.
  26. Deuces
    Deuces
    Congrats Kiwi!!! :D
  27. Deuces
    Deuces
    I turned an aluminum mask to cover the chrome rims on these Torq-Thrust mags from the newer BiG T model kit. I then sprayed the spokes with some hot rod grey primer.. Does it look convincing?? This was just a test piece just to try the mask out.. :D For the set of 4 mags, I plan on making some covers for the lug nutz using some styrene tubing that fit over the chrome lugs so they don't get sprayed..
  28. BIG-JIM
    BIG-JIM
    from CT
    I've been working on a 37 Hudson grille surround. What do you guy's think. It will be available in 1/8th & 1/25th scales.
    This is the 1/8th
    This is it going into rubber.
  29. indianhead74
    indianhead74
    Yep, I'm glad they've re-issued the ones I built as a kid. I took the Jag XKE to show and tell when I was in grade school. Dad helped the build a bit. I had to put a pure oil decal on the fender where I touched it with a gluey little finger. That car seemed huge but I was sure proud of it. My re-creation will include the decal without the extra glue smudge. Indy
