Anyone ID this bellhousing?
Discussion in 'The Hokey Ass Message Board' started by 3step, Dec 9, 2010.
  1. 3step
    3step
    Photos
      512.7 KB
      514.3 KB
      496.6 KB
  2. 3step
    3step
    Is it even a bellhousing? Looks like Slant 6 with the starter bump at the top left, but there is another bump on the bottom left. I don't even see how a fork would hook up, unless it would be on the right side. British?
  3. squirrel
    It's for an air cooled automatic transmission for an inline engine, but I don't know what....
    Are there any numbers/letters/symbols on it?
  4. pdq67
    pdq67
    V-8 Studes at one time had an air-cooled A/T. I want to say that it was like the early air-cooled Ford ******?
    Used non-detergent engine oil in it.
    pdq67
  5. 3step
    3step
    Thanks squirrel and pdq67. I will clean it up a bit and check for any markings. I didn't even think about it being for an automatic.
  6. 3step
    3step
    Jim, I found this on the bottom left. It looks like a date clock or just a symbol. The 9 could be an 8 and it could have a number at the ?
    Thanks, Wayne
      460.1 KB
  7. F&J
    F&J
    That's the Mopar symbol in the lower left, in case you did not know?
  8. 3step
    3step
    Many thanks F&J. I did not know that. I'm getting close, Desoto powerfite to 330?
  9. The37Kid
    The37Kid
    Chrysler, but I can't remember what. I had one, got tired of it as wall art.
  10. Chief_Wannabe
    Chief_Wannabe
    from Ozark, MO
    It's not for a DeSoto 330/Powerflite, which would be 1956. There are no cooling provisions on those. However, the bellhousing on my '57 Sportsman looks very similar to that. I'll see if I can get a pic of it in the next few days.
  11. F&J
    F&J
    I don't know squat about the old Mopar transmissions, but I thought they also had one called the clutch flight? I think an auto with a clutch just to get in gear, then shift without clutching?
  12. PBR STREETGANG
    PBR STREETGANG
    b&m made the "clutch flight" for mopar 727 and a "turbo clutch" for chevy turbo 400. They are really simple. Just a cut down automatic bolted to a ****ter shield with a bracket off of the clutch that spins the front pump. I have a friend with a turboclutch, and i believe it is for sale.
  13. F&J
    F&J
    I still think there was stock one in the late 40s to early 50's that had a clutch pedal. I'd have to look at an old book.:confused:
  14. daliant
    daliant
    Its a Chrysler slant 6 to a powerflite automatic trans bellhousing 60-61
  15. daliant
    daliant
    Those were the fluid drive transmissions. There were several different versions but it was basically just a standard transmission with a clutch and a fluid coupling. You could leave it in gear while stopped without deprssing the clutch.
  16. blackrat40
    blackrat40
    It looks like the bell housing that was on my brother's '53-'54
    Dodge with a Red Ram V8 small Hemi and a "semi-automatic"
    transmission that I believe was called a "Gyromatic".
    It had a clutch pedal and a column shift but I don't remember
    the details.
    Seems like you used the clutch pedal to put it into 1st or reverse and then you could stop with the clutch out and it was
    like an automatic then.
  17. squirrel
    sounds like we have a winner?
  18. 3step
    3step
  19. 3step
    3step
  20. squirrel
    the casting number does look like it's from 56, which rules out the slant 6? maybe behind a flathead 6?
