anyone know about these valve covers?
Discussion in 'The Hokey Ass Message Board' started by rainman, Feb 22, 2010.
  1. rainman
    rainman
    don't know much about ford motor stuff soare these valve covers large enough to fit over stock sbc covers like the lincoln y-block ones do if I weld a stud? not looking for opinions on what you would do or what I should do just an answer to my question. thanks so much
  2. F-6Garagerat
    F-6Garagerat
    Yeah I can't help it..... To use these good T-Bird covers on anything other than a Y-Block is just wrong. There I said it. But Lincoln Y's and Ford Y's are different.
  3. DirtyWoody28
    DirtyWoody28
    I have seen it done with , the steel y-block covers, but I think you have to cut the top off of the sbc valve covers and weld the y-block cover to it. I don't think it will be possible with the aluminum ones because they are thicker. Im sure someone has tried it, and I'm sure that a lot of people will be opposed to this idea, but maybe someone will chime in with a good answer.
  4. No, they are not large enough to fit over SBC covers.
  5. rainman
    rainman
    thanks for the help Homespun91
  6. xafalcongs
    xafalcongs
    Doubt these will slip over any SBC valve cover. The Ford Y-block has the same bore spacing as the 289/302/351C-W-M which is 4.38" while the SBC has a 4.4" bore spacing. The Lincoln Y-block has the same bore spacing of the Ford FE which is 4.63". Looks like you'll need to cut-n-weld to pull this off.
  7. scrap metal 48
    scrap metal 48
    Ford Y block covers will not go over a chevy's, only Lincoln Y block covers will work..Also old Caddy's,Olds and a couple others will slip over chevy's.....
  8. 29hotrod55kustom
    29hotrod55kustom
    dear god! not an opinion.. rather a plea.. im not a y-block guy.. but i know what finned t-bird covers go for... please.. for the love of christ.. dont cut them up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. buickvalvenut
    buickvalvenut
    from Rialto
    same here!....dont cut them up, have mercy. im a nailhead guy but the mere fact of cuting these up hurts.
  10. Deuces
    Deuces
    DITTO on the last 2 posts!!!!!!!!!! :eek:
  11. Cliffy
    Cliffy
    You'd be stupid to cut up a good pair, there are plenty of ones out there that *****s cut breathers in and hacked up over the years. Use a pair of those if your going to take the sawzall to them. Otherwise buy a pair of reproduction ones(yes the make them) and do it to those. Lincoln and Ford y-blocks interchange very little and the covers do not.
  12. hot rod pro
    hot rod pro
    from spring tx.
    cut them up! even if only to upset the ford guys.:D
    -danny
  13. Cliffy
    Cliffy
    then don't ever ***** about the price of vintage parts going up and up and up in price every year!
    Hmm, I wonder why?
  14. Deuces
    Deuces
    Ain't that the truth......
  15. rustyford40
    rustyford40
    from Mass Bay
    It is worth gutting them up to hide a **** box chevy
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    Relax guys and think about this...he obviously doesn't own the T-bird covers and they are probably for sale somewhere. He's thinking about buying them but wants to make sure they will fit before doing so.
    If he actually owned them, he could check the fit himself.
    He got his answer that they don't fit so they are safe...
    kidcampbell71 likes this.
  17. When exactly did the fascination with putting the wrong valve covers on your engine begin? If you are not proud of the motor in your ride, change it! And here's a though, instead of putting a small block chevy in everything, put something interesting in there.
    Look, some other guys make small blocks too!;)
  18. turdytoo
    turdytoo
    I saw a NASCAR show car Dodge a few years ago with MOPAR milled into the SBC valve covers.
  19. yes, that is sad. I also saw an altered wheelbase Dart with a SBC in it. Bad things happen I guess.
  20. Sphynx
    Sphynx
    from Central Fl
    Right that means my vintage parts become worth more !!!!:D
  21. dullchrome
    dullchrome
    from SoCal
    Just remember that if you polish a turd that when you are all done you still just have a turd. Think about it!
  22. TERPU
    TERPU
    Never go full retard!
    But Seriously Save the covers for somebody like me who loves the Y-block. If you put those on a SBC your car will never run right and the Gremlins will carry you away. I love SBC's but for goodness sake there are plenty of Y-blocks out there that run great and would love to be under those covers.
    Tim
