Looking for blueprints on building a leakdown tester to set up an injector setup. Almost anyone you talk to says ya hafta have a leakdown tester to check the barrel valve adjustments. Hilborn sells em for 170 bux!! It needs to be the dual gauge setup...thanks.
the most recent issue of street rodder shows how they fixed the tester they built incorrectly in the last issue.
Summit sells one for $65.99... I think a good set of gagues would cost that much... PN SUM-900010 FWIW, when I was an aircraft mechanic, I purchased mine for around $100... and it looks almost like the one in Summit sells... it sure was fun to use. Sam.
