Technical Anyone know of a source for 5/8" cloth covered fuel line?
Discussion in 'Traditional Hot Rods' started by banjorear, May 2, 2024.
  1. banjorear
    banjorear
    I got mine cloth covered 5/8" fuel from ThrottleAddiction.com (motorcycle source). They are out of stock with no timeline when it will be back in.
    Looking on line, I can't seem to find it. What I'm seeing listed is metric.
    Anyone know of source?
  2. oldolds
    oldolds
    Have you tried equipment dealers? Tractors and fork lifts used it. Metric would work. You just need to do a bit of math.
    firstinsteele likes this.
  3. banjorear
    banjorear
    That was my next search. You're right, metric will work, but I've found metric hose fit to be a bit off when getting it close to the SAE size.
  4. AccurateMike
    AccurateMike
    stubbsrodandcustom likes this.
  5. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    15.875 mm is 5/8" metric conversion. So 15 mm would be tight and 16mm would be loose but both are achievable to make fit on a decent fitting.
  6. pprather
    pprather
    Why 'cloth covered' fuel line?
    hrm2k likes this.
  7. squirrel
    5/8" ID?
    winduptoy likes this.
  8. Bob Lowry
    Bob Lowry
  9. banjorear
    banjorear
    5/8" O/D.
  10. banjorear
    banjorear
    I used it on outlet side of the fuel pump to the carbs. I just like the old timey look of it.
    alanp561 likes this.
  11. banjorear
    banjorear
    Correct. I'd rather not have to worry about close enough when it comes to fuel.
  12. Mike VV
    Mike VV
    from SoCal
    WHAT..are you feeding a 5/8" line full of gasoline ?
    That would be about 800 cubic inches at 9000 rpm...right ?
    Mike
    mohr hp likes this.
  13. banjorear
    banjorear
    The OD is 5/8". That is not terribly big.
  14. squirrel
    Fuel line is measured by ID, not OD.
    What size fuel line do you really need?
    Budget36, alanp561 and lurker mick like this.
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    .5 is 12mm and that's how most hoses are sold by the ID not the OD.
    Here is a link to something that will probably fit the bill on evilbay.
    https://www.ebay.com/itm/255542956180
    Budget36 and alanp561 like this.
  16. MCjim
    MCjim
    from soCal
    I.D. is the accepted way for fuel, oil etc. I was also wondering what the hell is he feeding...
  17. banjorear
    banjorear
    Interesting. I didn't know that. For years, I've bought it from the motorcycle supplier for years and that's how they've identified and I've purchased it by the O/D. I'll measure the I/D in bit.
  18. nochop
    nochop
    from norcal
  19. banjorear
    banjorear
    Damn, fellas. Thank you for the education. Turns out I've been referring to fuel line size incorrectly for years.
    Would you believe that by shear luck I actually ordered the correct hose yesterday, BUT I was worried I had made a mistake.
    The O/D is for sure 5/8", but the I/D is .316-ish which is 5/16" fuel line. I found a 32' ft roll of 5/16" clothed covered line at Tired Iron Tractor Parts for $27.00 and ordered it up. I was second guessing myself in thinking I had ordered incorrectly. How's that for dumb luck?
    All good and thank you for the education.
    Here is the link incase anyone else is looking for it.
    https://www.tiredirontractorparts.com/hose-fuel-5-16-braided-cover-32-ft-roll-a-fh516b/
  20. Mr48chev
    Guys tend to measure things differently by how they learn from the get go.
    When I was in Vietnam with A-1/9 Cav as a scout observer my side task was taking care of our platoon's generators so we could have lights in our hooches. Sent my helper for a 3/8 x 1-1/2 bolt and he came back with a small machine screw that took a 3/8 wrench because the head maintenance dude said that was how you measure bolts by the wrench size and we went a couple of rounds over that one.
    wfo guy, alanp561 and 1952henry like this.
  21. BamaMav
    BamaMav
    from Berry, AL
    That looks like the type of hose used on old VW bugs. They also used it from the master cylinder up to the reservoir.
    Bad thing about it is you can't tell when it starts cracking as all rubber lines do. Guess if you replaced it every year it would be OK.
  22. Mr48chev
    Thinking about it, my 2450 Bayliner has 5/8 fuel line as the vent hose from the tank to the little chrome vent outlet on the stern. Plus it may be covered as an abrasion resistant feature.
  23. carz
    carz
    from colorado
  24. Motoimpaired
    Motoimpaired
    Bought all mine from Amazon!
  25. Budget36
    Budget36
    Thank you for your service;).
    My company is one of 5 or 6 companies that are contracted with Amazon to take care of the building they have.
    From toilets that don’t work to conveyance problems.
    Just thought I’d add that!
  26. Ducbsa
    Ducbsa
    from Virginia
    Fuel Line.png [​IMG]
    The manufacturer advised me that the ID is 1/4". See attached email:
  27. banjorear
    banjorear
    Ducbsa,
    Thanks for posting. Seems like the person you spoke to either got the part number wrong or doesn't know what they are talking about.
    My fittings are machined for 5/16" hose and this hose slipped on without issue.
    It measured out at .309" which is a lot closer to .315" (5/16") than .250" (1/4").
  28. IronTrap
    IronTrap
    Thanks for the tip. I ordered a roll to have on the shelf. The European stuff that matched was a lot more expensive when I was buying it.
