Technical Anyone know the physics behind wire feed polarity?
Discussion in 'The Hokey Ass Message Board' started by willys36, Aug 16, 2024.
  1. willys36
    willys36
    Has anyone discovered why the polarity must be changed on the power feed wires on a wire feed welder when changing from solid wire to fluxed wire?
    Tow Truck Tom likes this.
  2. gimpyshotrods
    gimpyshotrods
    Electrode positive (DCEP) holds more heat in the torch. Better for thinner materials.
    Electrode negative (DCEN) puts more heat in the workpiece. Better for thicker materials, and necessary to get the flux to flow.
    Try it both ways. See how the bead either sits on the metal, or flows out into the metal.
    Unkl Ian, hrm2k and Tow Truck Tom like this.
  3. earlymopar
    earlymopar
    I hardly use the Pull / Backhand method as the weld is obscured......
  4. gimpyshotrods
    gimpyshotrods
    It's appropriate when you have a filler material that produces slag, such as flux core, or outer shield.
    If you push with flux, you risk including it in the weld.
    If it slags, it drags.
    427 sleeper likes this.
  5. Budget36
    Budget36
    My dad started me on stick welding. I was never great at it-45 years later I’m a bit better.
    But dragging the gun with the first wire feed welder I had, was natural.
    I did it like a stick welder, slight angle backwards, you can see the weld area easy.
    I’d guess if you can’t tell where to weld, you may have the gun at too severe at an angle.
    Nothing has come apart yet, so I’ll continue on.
    Fitty Toomuch likes this.
  6. Fitty Toomuch
    Fitty Toomuch
    from WVa
  7. willys36
    willys36
    What I have found is with flux wire polarity, running solid wire won't even strike an arc. Doesn't make sense to me since it is just electrical potential between two electrodes. Haven't made the mistake the other direction recently but as I recall the same thing happens. Won't even strike an arc.
  8. jetnow1
    jetnow1
    from CT
  9. jetnow1
    jetnow1
    from CT
    THANKS I learned something today
