Anyone know what this box in my engine bay is??
Discussion in 'The Hokey Ass Message Board' started by 6Deuce, Jan 2, 2010.
  1. plym49
    plym49
    from Earth
    Bingo. The coil and the capacitor tune it to the right frequency.
  2. 6Deuce
    6Deuce
    Not sure if i'll put it on ebay (i'll let u know first before i do), i'd still like to figure out what it is. It's definitely aftermarket because of the wiring that is hooked up to it. It might be the garage door opener? who knows.
  3. squirrel
    The big capacitor is probably for the plate power supply....but the coil sure gives away as being a radio thingy
  4. Thirtycoup
    Thirtycoup
    I'm guessin' it's a HAMB Radio :D
  5. Tweakers: you may never know what the original idea behind it was, although I'm sure it was "crystal" clear to them at the time!:D
  6. brg404
    brg404
    Did you ever trace where the wires end up inside? Also, if you can tell us the numbers on the side of the tube (like 12AX7) that would be helpful.
    I would expect some connection to an antenna if it were a garage door opener, and its not clear why there would be a transformer for a DC system. Does look rather homemade tho.
  7. RDR
    RDR
    Check elsewhere on the Caddie....maybe some dynamite planted somewhere....( a Mafia detonator gone bad???)....seriously tho' my old mans 66 Imperial (rest his soul) had so many GAS SAVING devices under the hood that it actually looked like a modern POS......Good try any way pa,.... still only gets about 13 MPG
  8. plym49
    plym49
    from Earth
    Yes, there will be some provision for an antenna in case it was a door opener or remote starter.
    That coil and capacitor are probably an indication of a tuned circuit, so then it is AC and hence the transformer. Without knowing what is underneath that box or mounted elsewhere it is hard to know everything that was intended.
  9. plym49
    plym49
    from Earth
    RDR has a point - you might want to ask your wife or GF to start that car for you from now on......................
  10. Its a flux capacitor. Necessary for time travel.
  11. Lalos53Ford
    Lalos53Ford
    Kinda looks like it could be an old reverb unit..
  12. OldBuzzard
    OldBuzzard
    Your box has all the things needed for a ******** type power supply for tube radios.
  13. mj40's
    mj40's
    Run Deuce Run!
  14. Buck Sharp
    Buck Sharp
    from nebraska
    OJ may have it i have it. i was going to say a reverberation box for the stereo.
  15. 64Cyclone
    64Cyclone
    If you master time travel, bring me a Crystal Pepsi back from 83!
  16. narducci
    narducci
    Thats the closest to what I thought. I beleive it may be a ******** power supply for a Ham Radio transmitter
  17. plymouth1952
    plymouth1952
    Just dont go 88 MPH
  18. Lalos53Ford
    Lalos53Ford
    WOW!!! I miss Crystal Pepsi... I remember walking to the store as a kid for one. And the TV commercial with Van Haggars "Right Now".. A bit O/T but good memories.
    Great bring back Cyclone!!!
  19. hotrod40coupe
    hotrod40coupe
    I think you are all on the wrong track. It is obviously some type of device used to communicate with extra terrestrials orbiting around the Earth.
  20. Ole don
    Ole don
    After you get it to 88 miles an hour, dynomite the brakes and hit the ****on, and the garage door will go up. Yup, that's what they looked like before modern electronics. It should have a cover on it.
  21. Falcon
    Falcon
    from nevada
    It looks like the lost Tesla box. See if you can drive for day's without any gas. Which direction are you going to go so we can look for you on the roadside if it doesn't work?
  22. NOTCH
    NOTCH
    what ever it is , it looks cool! restore it
  23. 64Cyclone
    64Cyclone
    A coil, a transistor and a capacitor. Audio related for sure.
  24. narducci
    narducci
    A transistor? surely you are kidding. I guess some youngsters have never seen a vacuum tube.
  25. stude_trucks
    stude_trucks
    Keep the box, good place to stash the gold chains, **** and booze.
  26. 64Cyclone
    64Cyclone
    lol...you can't vacuum with that little thing! (I meant to day tube...I've had a few today!)
    Good thinking!
  27. Hooligan63
    Hooligan63
    Or a back seat date at the drive in
  28. narducci
    narducci
    Sure you can, just break the top off and stick it in the dirt!
  29. lorodz
    lorodz
    great scott man haven't you ever seen a time machince
    haha ..flux capaciter.. ditch it ..
  30. Speedwagen
    Speedwagen
    could be an amplifier for an external loud speaker.
    A forunner to Mr microphone
