Technical Anyone know what this distributor is?
Discussion in 'Traditional Hot Rods' started by evobuilder, Dec 27, 2016.
  1. evobuilder
    evobuilder
    I haven't taken it apart yet, but does anyone know what distributor this is? I ***ume MSD by the red cap and it's somewhat modern look, but not sure. Tuning the motor tomorrow and will dig in, but not sure if I need a new cap and rotor or where I'd get it it's not generic Austin Parts store stock.
  2. evobuilder
    evobuilder
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    that is an HEI factory chevrolet dist that all chev v8's had from 75 up .... tha caps are normally black. that one is just a replacement cap
  4. jimcolwell
    jimcolwell
    from Amarillo
    SBC HEI good luck on starting your engine
  5. evobuilder
    evobuilder
    Ohh good, so I can get a cap and rotor at the local auto parts place? This is newer than anything I've ever worked on
  6. tb33anda3rd
    tb33anda3rd
    '74[?] to '90 gm hei
  7. slinginrods
    slinginrods
    from florida
    Just order a cap and rotor for a 1975 camaro 350 . The coil is under that smaller cap on top. Don't mix up the wires or forget the grounding strap. You can damage the module inside or the coil. One of the best factory electronic ignition ever made. Easily recurvable for performance up to 6500 rpms stock even higher with a msd module and coil. Known as the GM HEI
  8. evobuilder
    evobuilder
  9. jimmy six
    jimmy six
    Keep an extra rotor in the glove box. When you engine won't start or quits someday take the screwdriver you keep with the rotor and change it. There will be a hole in the center of it.
  10. uncle buck
    uncle buck
  11. evobuilder
    evobuilder
    Thanks..... got it all and now it's time to dial this motor in. Thanks.
