Technical Anyone know what this part is for?
Discussion in 'The Hokey Ass Message Board' started by 1961 Poncho, Mar 8, 2018.
  1. 1961 Poncho
    1961 Poncho
    from Las Vegas
  2. shivasdad
    shivasdad
    from Texas
    1956-62 Corvette alignment shims.
    egads, Squablow and Moriarity like this.
  3. F.O.G
    F.O.G
    from Pacific,Mo
    M-60 barrel brace, second series.
  4. FritzJr
    FritzJr
    1956-1962 Corvette Alignment Shim Front Aluminum
    This aluminum shim was found on all 56-62 cars, but can also be put on 53-55 cars. The addition of the tapered shim increases front wheel caster. Thickest part of shim goes toward rear of the car. To tilt the top of the suspension crossmember rearward, increasing the nominal positive caster angle and providing more range of positive caster adjustment, the tapered aluminum shim was added between the bottom of the frame and the top of the crossmember. This improved high-speed straight-ahead tracking and steering returnability at all speeds, and entered production at approximately 1956 VIN#4000 along with a modified steering third arm support bracket.
  5. earlymopar
    earlymopar
    Wow. What a ****py die cast part. I would hope the application doesn't a require a non-porous part!
    - EM
  6. jimvette59
    jimvette59
    Goes between the front cross member and the ch***is one on each side that is all.
  7. jimvette59
    jimvette59
    Those are pretty good , mine were almost gone.
  8. 1961 Poncho
    1961 Poncho
    from Las Vegas
  9. squirrel
    new $24 each. Yours could be worth more, if it has a good story.
