Technical Anyone make a small pull type master cylinder?
Discussion in 'The Hokey Ass Message Board' started by Deere boy, Jun 24, 2019.
  1. Deere boy
    Deere boy
    I need to run a hydraulic clutch on a project because mechanical linkage is practically an impossibility. It would be so much easier if I could find a pull type master cylinder. Doing a google search I only come up with one in some foreign country.
  2. It’s reversing the linkage.
    Bell cranks do that without fuss
  3. Deere boy
    Deere boy
    If I knew how to post a meme it would be the old guy from Napoleon Dynamite saying, "I didn't understand a word you just said."
  4. Automotive Stud
    Automotive Stud
    He's saying use a regular master cylinder and make a lever for the end that turns the pull motion into pushing in the master cylinder. Picture how a rocker arm turns the pushrod pushing up on it into pushing the valve down on the other side. Same idea.
  5. Deere boy
    Deere boy
    Okay, yeah I may have to do that.
  6. junkman8888
    junkman8888
    Pictures, we can't help you come up with a solution to your problem without pictures.
  7. FrozenMerc
    FrozenMerc
    Just order a small dual acting hydraulic cylinder (Parker will have a whole catalog of options for you). Vent the Cap side, plumb into the rod side, and add a spring return, if necessary.
    Your handle implies knowledge of farm equipment, so I am sure you have a shop / store near by that handles hydraulic actuators and supplies. I am sure they can help you out.
    VANDENPLAS likes this.
  8. squirrel
    That looks just like a Parker pneumatic cylinder....
    hmmm
  9. FrozenMerc
    FrozenMerc
    It probably is, I just grabbed a quick Google image to illustrate my point.
  10. Google reversing linkage and it will be more beneficial to understanding ,,,, there are all kinds of cool things to learn and adapt into your project
    WB69 likes this.
  11. Nitroholic
    Nitroholic
    from SoCal
    Use a Girling m/c or equivalent with a bellcrank........ 2005 01 01 006.jpg
  12. Deere boy
    Deere boy
    I can't find one on wilwood. Link?
  13. oldtom69
    oldtom69
    from grandin nd
    do you need the master cylinder or the slave cylinder?
    Hnstray and LM14 like this.
  14. john worden
    john worden
    from iowa
    That info was not correct. I deleted the post. Sorry about that.
  15. LM14
    LM14
    from Iowa
    Wilwood makes forward mount or reverse mount MASTER cylinder setups. Why can't you use a normal master cylinder?
    There are also push and pull type slave cylinders, Wilwood makes them, too. CNC also makes them.
    A picture or 2 of why you can't use a normal master cylinder would sure help people help you out. You have a clear picture in your head, all I have are voices in mine....
    SPark
  16. A sketch or picture of what you are trying to accomplish would sure help? What make/year vehicle, trans, master cylinder etc? I pull with a stock brake rod in my AVATAR.
    Charlie Stephens
  17. rusty rocket
    rusty rocket
    Speedway has pull slave cylinders.
  18. Slave and master are different
  19. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Would something like this work?
  20. BJR
    BJR
    Why not just use a cable from the pedal to clutch arm. Lots of cars had them.
  21. dreracecar
    dreracecar
    from so-cal
    Run a pair if more volume is needed [​IMG]
