Anyone make their own felt strips?
Discussion in 'The Hokey Ass Message Board' started by noxided, Aug 8, 2011.
  1. noxided
    noxided
    I'm looking to see if anyone has made their own felt strips that go at the base of the gl*** to keep it from scratching at the base of the window opening.
    I was thinking of buying a piece of aluminum and wrapping it with felt and riveting it on.
    I made a test piece and it looks great but the hobby store felt just doesn't seem durable.
  2. squirrel
    Used to be you could buy long pieces of it from any local gl*** shop, or from JC Whitney. They have some rubber molded in the middle, and the steel backing is notched so you can bend it around corners.
    I've never thought of makign my own, neat idea. Might look into using the soft side of velcro instead?
  3. cheveey57
    cheveey57
    What Jim said. Then to attach it I drilled 2 little holes about the size of a staple, and then used pieces of paper clips pushed through and twisted inthe back. They,ve been holding tight for over 6 years so far.
  4. noxided
    noxided
    I just looked on jc whitney and found them, thanks guys.
  5. Zeke
    Zeke
    Gonna have to remember this
  6. Blacklisted
    Blacklisted
    got a link? I did a quick search and didn't come up with anything.
  7. JC Sparks
    JC Sparks
    from Ohio
    A few years ago I did a industrial job that called for some felt. You can get a high grade of felt at mcmaster.com. It will bond great with 2 ton epoxy. JC
  8. rusty28a
    rusty28a
  9. Crystal Blue
    Crystal Blue
    Are you talking about window channel felt (u shaped), or the felt at the top of the door, where you rest your arm (fuzzies) ?
  10. Blacklisted
    Blacklisted
  11. noxided
    noxided
  12. vert1940
    vert1940
    i have used the fuzzy side of velcro with good results.they don't make a window channel the correct u shape for my car
  13. Twelvizm
    Twelvizm
  14. Blacklisted
    Blacklisted
