Projects Anyone making bead rolled panels
Discussion in 'Traditional Hot Rods' started by flyn schlosser, Nov 5, 2025.
  1. flyn schlosser
    flyn schlosser
    from Elko,NV
    Thinking of looking into bead rolled panels for some interior pieces for my 32 roadster..anyone making them for sale or someone i can contact...appreciate any information
    hrm2k likes this.
  2. Steve Reddy
    Steve Reddy
    I had to tin a drag car one time. I bought the Eastwood bead roller for like 150.00 did it all myself. Kinda fun actually!!
  3. 01Jazz
    01Jazz
    I also bought the Eastwood bead roller..had to reinforce it,,,used it to make floor pans for a sedan delivery,also made battery cover for K model IHC
  4. Modified harbor freight bead roller
    Modify a cheap-o bead roller. Make em yourself.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    I borrowed one and made my own steel firewall and floor for my fibergl*** t bucket a thousand years ago.
    flyn schlosser and hrm2k like this.
  6. rockable
    rockable
    Do your own. For what you'll pay someone, you can own a machine. I started out with a HF bead roller and upgraded as I did more. There are lots of YouTube videos out there. Check out Make It Kustom. Karl does very good videos and he explains the need to prestretch before you put the bead in it. If you don't, your panels will likely be wavey, especially if you try to put wide full depth beads in. Also, check out the site All Metal Shaping. There is a sub forum on bead rollers.
  7. lostone
    lostone
    from kansas
    Harbor freight with 15 % discount. A couple hours reinforcing and modding. Good to go. About 150.00 in mods...
    Took out a recessed spare tire well and replaced with these homemade panels..
  8. flyn schlosser
    flyn schlosser
    from Elko,NV
    Well I guess I will look into getting one ..it does sound fun learning to. I have watches a few of make it custom videos...gotta give it a try
  9. flyn schlosser
    flyn schlosser
    from Elko,NV
    Thank you appreciate all the information...
    rockable likes this.
  10. Fortunateson
    Fortunateson
    Karl is an exceptionally good instructor! And a hell of a nice guy as well…
    flyn schlosser and rockable like this.
  11. rockable
    rockable
    If you're doing interior panels, you will use aluminum, which is easier to work with and requires less rigidity in the bead roller. Depending on thickness, you may get away without prestretching. Good luck!
  12. grdra1
    grdra1
    I made these door trims out of 0.8mm cold rolled steel, I am a total novice and they are not perfect but they suit my style of ride. If you are planning to buy a bead roller get a motorized one ( believe me you will be glad you did ). Glen 35cf9c24-eac9-46b7-a723-a6d2d294ab7b.jpg 6451eac9-d257-4bed-8ca6-1f88970c9a5e.jpg
  13. oldolds
    oldolds
    Wow! Those look great!
  14. flyn schlosser
    flyn schlosser
    from Elko,NV
    Those look awesome and it's the kind of style im looking at...very cool...appreciate the information
