Projects Anyone making front "motorcycle" fenders for the Hi-boy?
Discussion in 'Traditional Hot Rods' started by hurlbird, Oct 22, 2023.
  1. hurlbird
    hurlbird
    Im not seeing them on line. Thinking about going that way vs. full fenders.
    Stogy likes this.
  2. A lot of guys back in the day would use the outside of the early spare tire carrier - it was perfect for this application.
  3. fabricator john
    fabricator john
    from venice fl.
    must be fabricated , none that i know of were ever commercially available, 36 ford spare tire rings were a popular starting point ( as mentioned by Bored & Stroked above ) you see the ones with the rib down the middle that's what they used ,, will take some work (or fab dollars) to make a set ,, but ya cant deny they are cool ..
    fabricator john
    miss you dad
    Stogy likes this.
  4. hurlbird
    hurlbird
    ill have to check them out.. Thanks
  5. Take a look at my Avatar roadster's front fenders.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    Your Local Trailer Supply Business Has Them..
    sdluck, Jibs, lothiandon1940 and 2 others like this.
  7. Stogy
    Stogy
    https://www.jalopyjournal.com/forum...ear-fenders-cycle-cycle-style-fronts.1189241/
    https://www.jalopyjournal.com/forum/threads/half-fendered-hotrods.1189042/
    There are a number of Threads on fabbing them and I have a couple Threads with plenty of inspiration...
    The Spare tire ring is most traditional/period correct and looks better than store bought trailer stuff...
    Spare Tire rings can be had for very little cost...Mine was literally given to me...
    I have to buy some 1 to 1 .25" x 1/4" flat bar to make the Bracketry but its not rocket science just a bit of cypherin and guzintas with a bit of drilling and welding...
  8. flynbrian48
    flynbrian48
    '36 Ford spare rings are indeed the right way to go. I had a '37 Buick sidemount cover that had the same bead down the center, and used that to make two rear fenders. It'd have been nice to have two, because they ended up a bit short on the rear, but they looked cool as hell. They fit better of 7.50X16 tires than the skinny Fords. Trailer fenders look like trailer fenders...
    Okie Pete, Outback, vtx1800 and 3 others like this.
  9. Stogy
    Stogy
    :rolleyes:...I wanted a smooth non beaded ring as I have smooth Trailer fenders on the back which surprisingly was available in 1957 and used on Hotrods, mind you they may have been Steel..my backs are aluminum but if I run bare metal with clear coat it matches the back very well I was surprised...
    https://www.jalopyjournal.com/forum/threads/pics-east-coast-hot-rods.314683/page-30#post-11772458
    :rolleyes:...I was pretty happy to find this pic which is around 1957ish...This is a Hambers Dads Hotrod ... Mine are attached to the wheel-well as stock are but this looks to have strut to backing plate like the fronts and they look pretty nice in my opinion...
    TrialByError, 2Blue2, mgermca and 5 others like this.
  10. AccurateMike
    AccurateMike
    Google "steel motorcycle fender blanks" or "builder blank fender". Looks like you can get just about anything. Mike
  11. GordonC
    GordonC
    Made a set for my roadster from an old spare tire ring that I bought for $20.
    Jacksmith, Dino 64, Okie Pete and 4 others like this.
  12. Stogy
    Stogy
  13. GordonC
    GordonC
    I don't have some at hand Stogy but I can grab some if you give me a little bit. They were pretty simple really. All I did was weld some large nuts to the back of the front backing plates. Then I used flat bar welded to the side of the fender with an inner piece shaped to the curve of the fender. All of that was welded on the fender. Which I then attached by bolting it to the back of the backing plate. I'll go grab a couple shots of the fender mounts...
    Stogy likes this.
  14. Stogy
    Stogy
  15. Stogy
    Stogy
  16. GordonC
    GordonC
    Here you go Stogy. Mine are pretty much the same as what was posted just above. The only thing I didn't do was a cross brace between the two supports which I was planning on adding.
    20231022_175045.jpg View attachment 5875609 View attachment 5875609
    mgermca, vtx1800, Okie Pete and 4 others like this.
  17. GordonC
    GordonC
    Sorry pics got messed up.
  18. Stogy
    Stogy
  19. Ebbsspeed
    Ebbsspeed
  20. HOTRODPRIMER
    HOTRODPRIMER
    Check out your local motorcycle shop, if they don;t have them in stock they can order one from their suppliers, when I was building bikes they were available in several widths. HRP
    GordonC and Tow Truck Tom like this.
  21. caprockfabshop
    caprockfabshop
    Stogy likes this.
  22. hurlbird
    hurlbird
    awesome thanks all
    Stogy likes this.
  23. GordonC
    GordonC
    Stogy my supports are 1 1/2" x 1/4". I didn't want to take a chance they would break.
    Driver50x, RICH B and Stogy like this.
  24. alanp561
    alanp561
    lothiandon1940, RICH B and Stogy like this.
  25. hurlbird
    hurlbird
    very cool. probably a matter of style but i wonder if there is too much fender used for the motorcycles?
  26. hurlbird
    hurlbird
    your set up is EXACTLY white im thinking for both front and rear. How long are those front fenders?
    GordonC and Stogy like this.
  27. alanp561
    alanp561
    As in too long, too wide, too much what? Ribbed fenders are about as traditional as you can get. Determine what width you need for the tires you have, and cut them to what length you need. It's not rocket surgery.
    mgermca, Jibs, lothiandon1940 and 2 others like this.
  28. GordonC
    GordonC
    hurlbird the fronts are about 30 1/2" long. Kind of hard to get a steel tape measure to follow the curve of the fender!:D I run bigger diameter tires on the rear. The front fenders work with 6:50/16 and 560/15 tires. I did have to adjust the mount position tho when running the 560 Firestones. I just bobbed stock A fenders for the rear.
  29. Stogy
    Stogy
    :rolleyes:...Hotrod looks awesome Gord...
    GordonC likes this.
  30. GordonC
    GordonC
    Thanks Stogy!
    Stogy likes this.
