Projects Anyone recognize this flathead ford intake
Discussion in 'Traditional Hot Rods' started by Nasty-Nathan, Jun 22, 2021.
  1. Nasty-Nathan
    Nasty-Nathan
    Trying to identify both of these intakes and any help tuning the dual carb D&S setup, the lower end is stroked and bored as large as I'm told it can possibly go PXL_20210623_023959450.jpg PXL_20210623_022831682.jpg PXL_20210623_033450622.jpg PXL_20210623_023959450.jpg PXL_20210623_022831682.jpg PXL_20210623_033450622.jpg . Two brand new Stromberg 97 Chinese re-pops from speedway magazine and it just seems to be extremely fat and loads up. Any info on the 4 carb setup would be awesome can't find another one like it ? No names or tags anywhere on it.
    Tim and kidcampbell71 like this.
  2. Nasty-Nathan
    Nasty-Nathan
    1931 model a frame with a t bucket body
    Surfcityrocker likes this.
  3. Mike VV
    Mike VV
    from SoCal
    I'd use small paper filters on those things to make sure that they get a full breath of fresh air..! I don't think those scoops would help any but the first carburetor on the freeway of a faster city street, except to FU the air flow.
    Mike
  4. X38
    X38
    Well they are ****.
    Do a search here, plenty of information about them. And real Strombergs.
    warhorseracing and 97 like this.
  5. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Looks like Edelbrock. Rear fuel pump on intake rotated where is is turned more than usual. B7B6FE3E-9EFE-48D8-B193-0ACD3286F3E4.jpeg 093ED563-519B-4678-BA7B-EFBBBFF7A64A.jpeg
    kidcampbell71 likes this.
  6. Speed Gems
    Speed Gems
    The 4x2 intake is probably an Edelbrock and not good for anything but all out racing.
  7. 1 Carb will do the Same or Better than all those Carbs, They Look Good
    But They are ****.!
    Just my 3.5 cents
    Live Learn & Die a Fool
  8. Marty Strode
    Marty Strode
    It looks like the carb spacing is wide enough to fit 94's, like an Edelbrock 4-59, most flathead 4 juggers won't. My Sharp unit will, but it's different than yours. IMG_4831.JPG
  9. saltracer219
    saltracer219
    They work just fine if you build the engine to handle them.
  10. gary macdonald
    gary macdonald
    Take the carbs apart , clean any debris, replace the economizer valve aka power valve ,even if they look good . Be sure to ket the correct type . Set float heights , no more than 3 lbs fuel pressure . Get car running , use a vacuum gauge , check plugs to determine rejetting and possibly new power valves again , depend on your vacuum and driving habits .
  11. Bandit Billy
    Bandit Billy
    Speedway doesn't sell Stromberg's, they sell problems that look like 97's
    1 is good, more is better! My blown flatty has progressive linkage on my trio of 97's. Runs okay on one but when the other 2 kick in you had better be paying attention.
    ^^^^This
  12. 97
    97
    AND after all that is done when you discover they are no better than before send them back to China in the s****!
    They are a waste of time and money , you shouldn't have to do any of this with NEW carburetors.
    Spend the money and get a set of originals rebuilt properly or buy a set of new proper Genuine Stromberg 97s .
    Buying from Speedway is like buying rotten fruit at half price .
  13. Ratspit
    Ratspit
    Here is a picture of the Edelbrock 4x2 I sold a while back. Looks like a match to me.
    kidcampbell71 and Speed Gems like this.
  14. Speed Gems
    Speed Gems
    Here's the two together for reference.
  15. alchemy
    alchemy
    Strombergs (and probably the junky repro 9super7) don't have power valves that blow out like a Chandler Groves does. They have a ball and spring in them that should be reliable, and actually only get activated on full plunge of the top plunger. I doubt that's his problem with the Speedway carbs.
    If they were my car and parts, I'd steal two of the real Strombergs off the big intake, rebuild them with genuine Stromberg rebuild kits, and put them on the T.
    Bluefox and gary macdonald like this.
  16. gary macdonald
    gary macdonald
    You are correct , I just bought some ebay chinese replacement carb , ford copies , for my 41 and they have the power valve . Just mixing chinese junk , I couldnt afford the speedway version .
