Anyone recommend a good diagnostic stethoscope?
Discussion in 'The Hokey Ass Message Board' started by morepower, Sep 10, 2011.
  1. morepower
    morepower
    from northeast
    Attempting to isolate valve train and other internal engine noises. There's many stethoscopes on the market, ranging from ye old doctor type all the way up to fancy digital. Any suggestions for a good quality unit that gets the job done?! Thanks.
  2. tommy
    tommy
    They are so cheap I don't think quality is an issue. Mine has last 25 years. no batteries required. Great for finding bearing noises. JMO
  3. gimpyshotrods
    gimpyshotrods
    5/8" or 3/4" heater hose, and an earplug for the other ear.
  4. Deuces
    Deuces
    I got a cheap plastic one in my tool box... Works great!... :)
  5. Engine man
    Engine man
    from Wisconsin
    I always used the doctor style with the metal probe. You can take the end off and use the open tube to find air and vacuum leaks. Lately I started using the electronic type.
    Here are some good units.
    http://www.steelmantools.com/Diagnostic-Tools.htm
    I've also seen a unit that connects to a laptop and gives a visual of the frequency of the sounds.
    I've used everything from a broomstick to the modern electronic tools. As I get older my hearing isn't as good so a visual representation helps.
  6. morepower
    morepower
    from northeast
    Thanks everyone... found a good "****og" version on Amazon!
  7. oil'n'rust
    oil'n'rust
    from NewZealand
    allways used a bit of wood, like a skinny broom stick only shorter
