anyone run a drawer pull grill? i need some help
Discussion in 'The Hokey Ass Message Board' started by borndead327, Oct 5, 2006.
  1. borndead327
    borndead327
    what do yall use for backing? i went to home depot and lowes lookin for some kinda expanded metal any help would be appreciated
    thanks
    dave
  2. HotRodDrummer
    HotRodDrummer
    Plowboy had close to $100 worth on the lander.....PM him, but he probably won't get back to you til Morning....
  3. borndead327
    borndead327
    thanks
    anyone else??
  4. teddyp
    teddyp
    What Car? I Used A 58 Ford Grill It Works And Fills The Grill Shell
  5. The stuff you are looking for is perforated steel. Try McMaster-Carr and do a search on perforated steel they have many styles, hole sizes and materials to choose from. Just call, place order and it will be on a truck to you in a few days. They stock almost everything imaginable and usually overnight delivery. Check them out: McMaster-Carr
    Hope this helps!
  6. hotrod54chevy
    hotrod54chevy
    from Ohio
    also if you go to pepboys or the 'zone or the like,in the import section they have perferated metal i believe in flat black an some other colors that tuners stick behind their grills.a few friends of mine have used it for similar grillwork.
    creepy
  7. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    if you can find that metal that has all the holes drilled in it it works best,the holes are a tad bit smaller than the knobs screws are witch works to your benifit once every thimg is laid out and drilled it makes it easyer to do finall assembly.on my daughters bonnivile we use the smalest expanded metal we could find for a diferant look on the back drop but was harder to get every thing lind up!
    picks of both my wifes car and my daughters car can be seen on my intro page!
  8. continentaljohn
    continentaljohn
    The Meca of expanded metals is
    mcnichols.com
    That's all they do and will make custom if you want to pay:D
  9. This is the route I wanted to go. I didn't want knobs though, I wanted pulls. I tried to find simple chrome 6"-8" length pulls, but really couldn't. What I did find was so expensive that 30-50 pulls would have killed my wallet.
    I still plan to lay in the expanded metal, then mount a shaved down front Opel GT bumper which I already have in my garage. It will basically be a "floating-grille" style instead of the knobs/pulls.
    The knob idea is so much more simple to build for me and my resources, I wish I'd be more happy with a set-up like that. Maybe I should rethink it, again.
  10. ProEnfo
    ProEnfo
    from Motown
  11. TagMan
    TagMan
    I put mine (126 of 'em) in the stock '55 Buick grill. This winter it's all coming apart and I'll paint the grille flat black, so the drawer pulls will "float".
  12. williesplace
    williesplace
    from campbell
    I used the perferated metal also.Used 4" drawer pull handles from Orchard Supply,about $4 apiece.Then I mounted 1959 Bonneville fender spears on top of them to make them floating.I also tapped the tips to mount bullets.Total cost of grill $50!!!!Goes to show,don't have to spend alot of money,just give yourself some time to for you mind to work??Tried to upload pictures but can't.You can see on my web site........Williesplace.com
  13. can you give us a close up shot on the grille?
  14. Just a thought about a source of pulls/knobs. They have gotten a bit costly for some styles at the store. Maybe you could find some used ones still in good condition at a flea market, junk store, rummage sales - usually they practically give them away after the kitchen remodel. Also, have you considered using more than one type, some that would work together for an interesting design? Also, maybe they could be mounted on some flat bars for a simple horizontal layout, sort of like a 59 Buick. Have never built one, but have seen some pretty nifty home made grilles.
