Technical Anyone run the same wheel size both front and rear?
Discussion in 'The Hokey Ass Message Board' started by moonami, Sep 27, 2015.
  1. stanlow69
    stanlow69
    The car in my avtar has the same size wheel. I wanted alittle rake to it which is done with suspension modifications. The rear tire, I wanted it to appear larger with the smaller wheel well opening. So I went a tire size bigger with a little wider whitewall. If I didn`t do this, the front tire would appear larger than the rear with it`s larger wheel well opening. Which wouldn`t look good. Look closely at side profiles and most front tires appear larger than the rear tires due to the shape and size of wheel wells. .
  2. 50dodge4x4
    50dodge4x4
    All 4 tires and wheels are the same on my car. The rake is in the suspension.
  3. moonami
    moonami
    Sounds good. I'm probably going to try a 17x7 front and a 17x8 rear wheel. Test fit some tires and see if my current suspension setup gives me the rake I'm looking for.
  4. Same 35 ford wires, front and back with 6.00 front tires and 7.00 rears. 33atspeed.jpg
