Anyone runnin' 17" wires?
Discussion in 'The Hokey Ass Message Board' started by Crankhole, Jul 10, 2006.
  1. Crankhole
    Crankhole
    Bought a set of '34 Ford wire wheels thinking they were 16" 1935s. Shoulda had my measuring tape. Anyways, anyone using 17 x 3.25s? Pros/cons? What is the widest tire that I can run on these? Know if I can get a nobby military tire to fit these? Couldn't find any on the Coker site. Someone point me in the right direction please. Pics are always appreciated.
  2. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    It doesn't seem that many people are using them, About two years ago, before everyone started using the 16" wires we had about 80 16"ers and about 50 17"ers, Now we dont have any of the 16s left but still have all the 17s. What do you want pictures of?
  3. dana barlow
    dana barlow
    from Miami Fla.
    Would help to know how to size them 16in? 17in.?,it seem Ez to get between rim lips for how wide,but can they just be sized OD? all the way across out side to out side so 16in.=__________?:confused: or is there a set of number stamped under the rust & drit anyplace?
  4. chrisntx
    chrisntx
    from Texas .
    I bought 4 tires and tubes from Coker for my 17s. Cost me $600
  5. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    16s will be about 17" OD and 17s will be about 18" OD
    Heres a part of something a wrote a little while ago and it gives some ways to tell them apart without measureing and has some pictures
    Thanks,
    Jimmy
    32
    These are 18"x3 1/4" wheels with welded spokes. The spokes are single cross on top and bottom. Hubcap hole size is 5 3/4, as is the rest of the wheels mentioned here forward. Unlike the two Model A wheels the lugnuts on these are covered by the hubcap.
    33-34
    These are 17"x3 1/4" rims that are pretty much the same as 32s.
    35
    Same as 32-34 wheels but they're 16"x4" These are by far the most plentiful because back in the war years, when a car needed new tires, a set of these wheels with new tires could be had for less than a set of 17" or 18" tires because of the price of rubber if you could find them. A good way to tell these apart from 17s and 18s without measuring is the valve stem hole. The 16" has a normal hole in the flat part of the rim, while 17" and 18" have the hole in a humped up area. (see pictures of the 17" and 18")
  6. KutThrtKustms
    KutThrtKustms
    from SO.CAL.
    Cooter, thats what you get for not selling me one of those 16" I meand 17" wires!! :)
  7. Crankhole
    Crankhole
    Still want one KutThrt?:D
    So, does anyone know how wide of a tire I can put on these?
  8. caffeine
    caffeine
    from Central NJ
    i run 17's on the back of my sedan, i just ordered firestones from coker. in 17x7 with 16x6 in the front
  9. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Here is a pic of my bucket with 17's on it. The rear tires are Vintage columbia 5.25/5.50 17 and the fronts are excelsior 4.25/17 from Coker. EVILT
  10. Crankhole
    Crankhole
    Damn, you put a 7" wide tire on a 3.25" wheel? That's not gonna cause any problems?
  11. 31hillard
    31hillard
    im running 17" on my volksrod!i have some 4.50x17 firestones on the front and 700x17 firestones on the rear!
  12. J Man
    J Man
    from Angola, IN
    On my T I have 17s in the back, 16s in the front. If I remember right I am running a 600/650 tire, bought them from Coker
      77.6 KB
  13. chrisntx
    chrisntx
    from Texas .
    I did that for 20 years with no problems. Of course if you listen to what others say, they will try to convince you not to do it.:)
  14. Crankhole
    Crankhole
    Sounds like I'll be using them...eventually. On the wall for now. Thanks all.
  15. caffeine
    caffeine
    from Central NJ
    i dunno how wide they are, but im running 17x7.50s on there now :eek:..but firestone doesnt make a matching blackwall in 7.5 so i got 7. here is a pic.
    in fact my tires SHOULD/BETTER be here today, ordered them before the 4th.
