anyone running a 351w in 57-60 f100
Discussion in 'The Hokey Ass Message Board' started by Mellowgt, Mar 26, 2013.
  1. Mellowgt
    Mellowgt
    What transmission combo are you running? Weighing my options of swapping my 292/3 spd combo. They both need rebuilt so now I'm back to the drawing board.
  2. Mellowgt
    Mellowgt
    Wanting to stay manual if I can some how.
  3. 51fordshoebox
    51fordshoebox
    Stepdad has a 59. Had a 351w with an srod 3+1 od trans. Now has a 302 with t5 in it.
  4. Mellowgt
    Mellowgt
    Tell me a little bit about the t5 setup? Was there and issues with shifter hitting seats or cross member fitting? What Speedo and clutch pedel setup dis he use? Original hyd setup? Thanks.
  5. FrozenMerc
    FrozenMerc
    I would strongly suggest looking for an M5R2 out of a Mid 90's F-150. The shifter location is much better then a T5, and they can normally be had for less then a T5, and it will bolt directly to a 351W. I run one in my '51 F-1 behind a Windsor, the gear ratios are perfect, and the shifter was within a 1/4" of the stock location. The main downside is it is a big transmission, not heavy, just big.
  6. Mellowgt
    Mellowgt
    Did you have to fab up your own cross member to support that thing?
  7. R Pope
    R Pope
    I put an M5R2 behind my 351W in a '66 Ford pickup. The shifter comes out the same hole that the farmer 4 shifter did, and the rear X-member just had to be moved back a few inches and new holes drilled in the frame rails to bolt it to. Mine was a 4 speed, I think that you might have to find a floor hump out of a 4 speed truck for clearance, as mentioned above, it's a BIG transmission.
    The hydraulic clutch setup caused some headscratching to get it hooked up, but it can be done.
  8. I have a M5R2 behind a 302 for my 60. FrozenMerc is correct about it aligning almost perfectly.
    Jeff
  9. Molonewolf
    Molonewolf
    I run a 351W with a AOD , I like it. Easy install.
  10. Mellowgt
    Mellowgt
    Thanks for the help!
  11. 5Tony7
    5Tony7
    Hate to bring up an old thread. By chance does anyone know if I need to remove the stock transmission crossmember to install a 351w and c6? Using the Transdapt motor and trans crossmembers. Thank for any advice.
