Anyone tried Alumaloy?
Discussion in 'The Hokey Ass Message Board' started by mytlo56, Jan 2, 2004.
  1. http://www.alumaloy.net
    A little skeptical, but I saw it on TV the other day and like the idea.
    You clean the area w/ a stainless brush, heat the metal w/ a torch, and rub the alloy stick across it until it melts & fills the hole.
    If it works this'd be a good way to shave badge and emblem holes.
  2. shoebox72
    shoebox72
    I bought into that scam. The only thing I was able to fill was a hole in a beer can. Maybe its just the propane torch I got but it didn't work for me. The repair section has to be absoloutly clean or it won't stick. I tried to fix a crack in an aluminum intake and it didn't do shit. Maybe it's just me.
    Billy
  3. Deuce Rails
    Deuce Rails
    I haven't tried that brand of aluminum solder, but I did pick up a bundle of similar stuff at Carlisle a year and a half ago.
    It works exactly as promised. Heat the base metal with a propane torch, and then apply the rod. Let the heat from the base metal melt the rod. It's got a high tensile strength for solder.
    Having said that, it's no substitute for actually welding aluminum to aluminum.
    How do you plan on using it?
    --Matt
  4. Deuce Rails
    Deuce Rails
    Sorry... I just re-read your post. I don't think that you can use this stuff to fill badge and emblem holes, unless your bodywork is aluminum. I also don't know how to properly prime and seal it for painting.
  5. Unkl Ian
    Unkl Ian
    [ QUOTE ]
    From the Alumaloy site:
    If it's Aluminum ... you can fix it!
    Now, with Alumaloy™ and just a hand held propane torch you can repair, weld and fabricate anything made of aluminum, mag alloys or any white pot metals safely and affordably without extensive knowledge or training
    [/ QUOTE ] Doesn't sound like it will stick to Steel.
  6. polisher
    polisher
    Alliance Vendor
    They got another one for steel and one for cast iron.
    Pretty funky, I have to try it.
    If it works and it's plate-able it can maybe save some of my customers a lot of money, and me a lot of grief.
    I tried one of these super aluminum solder deals and it didn't work out.
    But it's worth checking out I reckon.
    Somebody has to, huh.
  7. Used some rod like it[from westlakes ACE hardware] it fixed a 50 olds grille bar broke vertical in the middle] but I couldn't get it to stick to STEEL at all either......
  8. Paul
    Paul
    Editor
    [ QUOTE ]
    [/ QUOTE ]
    where can I get some of this stuff?
    I gotta leak alomost every other beer! [​IMG]
    Paul
  9. shoebox72
    shoebox72
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Paul
    [/ QUOTE ]
    I don't think this stuff will help you much, You know dam well beer is rich in vitamin P.
    Billy
