Technical anyone tried CLR to unstick a frozen short block?
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Aug 3, 2015.
  1. falcongeorge
    falcongeorge
    from BC
    Just curious, I have a rust seized short block here I am trying to un-stick, its on its second treatment with the atf/acetone mix. Just wondering, has anyone tried CLR for this? Hey, the label says it "dissolves rust", right? Or am I going to be the guinnea pig?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I've always used Coke,,it works. HRP
    volvobrynk likes this.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I think you will be the "guinnea pig" !
    I hope it works for you, you will be a pioneer!
    KK
  4. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    With or without a straw?
  5. thebigdaddyo
    thebigdaddyo
    Coke, then Marvels
  6. HOTRODPRIMER
    HOTRODPRIMER
    :rolleyes: HRP
  7. falcongeorge
    falcongeorge
    from BC
    I cant get marvel in Canada anymore.:( I'll give it a couple more days with the latest dose of AFT/acetone, if that doesn't do it, I'll give the CLR a shot. Pretty good test, if the 50/50 mix cant do it, and the CLR does, that is pretty impressive, not that I really expect it to work...
  8. blowby
    blowby
    from Nicasio Ca
    I believe it's the phosphoric acid in both Coke and CLR that hits the rust (though it may have been removed now, at least from CLR). Same stuff as in metal prep and wheel cleaners. I use it all the time for light rust removal, might try it on a cylinder but not sure how it reacts with aluminum, check around.
  9. Mark T
    Mark T
    How about some Kroil, Their website says it creeps into millionth inch spaces, breaks bonds due to rust, corrosion, contamination, or compression and lubricates to loosen frozen metal parts.
    http://www.kanolabs.com/
    da34guy likes this.
  10. da34guy
    da34guy
    After you've used coke,clr Marvel, atf or any thing else, try to spin it backwards first.
    you'll be pulling away from the rust not trying to push thru it. Has worked for me m,any times. JMHO.
  11. falcongeorge
    falcongeorge
    from BC
    The pistons are wasted anyway. I am trying to get it to turn over so I can remove the trans. yanking the trans input shaft out of the converter with the converter bolted to the flex plate will often damage the input shaft id rather avoid it, but if push comes to shove...
  12. falcongeorge
    falcongeorge
    from BC
    I have leaned on it in both directions
  13. southerncad
    southerncad
  14. F&J
    F&J
    well.....no matter which rotation...some pistons will be pushed up and some will be pulled down..unless you have some special kind of motor ... like a one banger
    Travis T, blue57ford, belair and 2 others like this.
  15. F&J
    F&J
    I never use the crank bolt to break the pistons loose. I always work with the flywheel teeth against either a starter opening or a bolt in one bell housing hole...something close to the teeth to give the most pressure on the fulcrum principle. I have a variety of straight and angled pry bars
    i only look for a few thousanths in either direction at first, before really going at it.
  16. BamaMav
    BamaMav
    from Berry, AL
    I've always liked PB Blaster. Got loose some really stuck nuts and bolts for me.
  17. 56premiere
    56premiere
    Bust the center out of the pistons , or hole saw them if you don't care.
    BigChief likes this.
  18. thirtytwo
    thirtytwo
    I just used evapo- rust to clean a 32 gas tank , it worked slow but worked good , didnt attack other metals in it , you can buy it by the gallon or orielly has 5 gallon buckets also pretty sure it is ok for cast iron also
  19. Atwater Mike
    Atwater Mike
    Coca Cola is a dollar a 2 liter bottle here, (Walmart) and the ads don't lie.
    "Things" go better with Coke.
  20. blue 49
    blue 49
    from Iowa
    A friend of mine says he has used muriatic acid on stuck engines, but be sure you have plenty of material to bore. Fumes are very nasty, too.
    Gary
  21. Fortunateson
    Fortunateson
    I thought I've seen MMO at Canadian tire, or was it Lordco? If I see it next time I'll send you a PM.
  22. Fortunateson
    Fortunateson
    I had great success with Moovit available at Princess Auto.
  23. falcongeorge
    falcongeorge
    from BC
    I checked Canadian tire a couple weeks ago, no dice. I heard they used to carry it a few years back. I am going to try the CLR on the other bank tomorrow, I'm curious.
  24. thirtytwo
    thirtytwo
    I tried murratic acid once on cast iron , the cylinder turned to dust.. It seemed to pull the carbon
    F&J likes this.
  25. mbat
    mbat
    from Ohio
    If you want to stay safe then Kroil is excellent and give it plenty of time (days maybe a week or two) and a squirt a day. If you are in a hurry and don't care too much about other metals being damaged, rubber seals damaged, etc. Then I'd use muratic acid with goggles, a respirator, and excellent ventilation. Be careful and good luck. Have a plan for an eyewash and rinse your skin in case of contact. Wear tall nitrile gloves too.
  26. Jakesrocks
    Jakesrocks
    If all else fails, use an old timers trick, Oil of wintergreen. Best damned penetrating oil you can get. We used it in the navy to free frozen multiple disc clutches on Grey Marine diesels. It'll get rid of mice in your shop & kill*****roaches too. Just don't get it on your skin or in your eyes. Burns just like a hand full of hot barbeque charcoal.
  27. aircap
    aircap
    Find this stuff called "Knock'er'loose".
  28. stillrunners
    stillrunners
    from dallas
    "Knock'er'loose".....no no....I can't say it....
  29. stimpy
    stimpy
    No phos acid in CLR , they use lauramine oxide ( a form of amine) to remove the rust .
    I doubt it would work on heavy deposits as amine solutions only work on ferrous oxide or iron in a small amount ( stains ) , but will not touch Aluminum ,
    to dissolve the aluminum piston use sodium hydroxide ( LYE ) mixed with water it will change to aluminum hydroxide so your going to need a decent amount ( 1 gallon or so ) ,if you can get industrial Hydroxide ( caustic soda ) it will work better , nuetralize with Vinager and water ( and wear PPE as it will eat flesh and instantly blind you if you get it in your eyes ) and the powder will stick to your hands
  30. seb fontana
    seb fontana
    from ct
    Cutting torch to the rods, or unbolt from crank and pound out unless you want to save them....Vinegar would have been my first choice, tried clr in a radiator and didn't do much at all but seems to work on house hold stuff..I don't know what engine but here is a wild one: Take all the rod caps off, main caps off, knock out bell housing dowels out and remove crank and trans as an****embly sliding everything down from pan rail...:)..
