Projects Anyone up for some small lathe work in socal/Las Vegas?
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Jun 1, 2020.
  1. iwanaflattie
    iwanaflattie
    Hello men.
    I need to build this studs with weld then have someone turn them to fit a bronze bushing over it..
    I can mail these..
    Lmk if someone can help ..I'll be glad to pay for it IMG_20200531_092223.jpg
  2. squirrel
    Shift linkage?
  3. iwanaflattie
    iwanaflattie
    Yes for a 63 econoline I can't find replacements
  4. john walker
    john walker
    How about cutting off the ends, drill and press in a steel bar the proper size?
  5. Boneyard51
    Boneyard51
    Cut the pins off, drill and tap threads in there and loc***e a bolt in the threads and then cut the bolt to the right length. If you can’t fine the exact size bolt, go to the closest bigger size and drill out your bushings. Ot chuck the up in a drill and turn them and hold a file to reduce size. These things don’t have to be perfect to work, they are adjustable.
    Bones
  6. iwanaflattie
    iwanaflattie
    Those are actually great ideas...I'd probably drill em off center tho
    tb33anda3rd likes this.
  7. squirrel
    I was going to suggest just using the bench grinder to get it close. Like has already been done.
    the linkage goes through a hole in the body that we can't see, so you really don't want to cut the ****** off. Not much thickness to put threads in
  8. iwanaflattie
    iwanaflattie
    HF sells a 2" Chuck for 30 bucks I'm gonna stop and see if they have it in stock,then will Chuck that on my bench drille and use that as a lathe with a file or grinder
    Boneyard51 likes this.
  9. RichFox
    RichFox
    Looks like something I could do if you weld them.
    kidcampbell71 and Budget36 like this.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    It would become an ashtray if I did it for you...
    kidcampbell71 and 41rodderz like this.
  11. continentaljohn
    continentaljohn
    What are the dimensions of the linkage and can you post better pictures so I can take a look and machine some. It looks to me you can machine a bolt to match your part.
  12. iwanaflattie
    iwanaflattie
    Thanks guys I'll take some measurements when I get home...btw I don't have the linkage with me but I can mock or down load pics
  13. iwanaflattie
    iwanaflattie
    Very kind offer I can weld them for sure.
    Will send u a pm
  14. continentaljohn
    continentaljohn
    kidcampbell71 likes this.
  15. iwanaflattie
    iwanaflattie
    Very kind offer...thank u in advance...
    I am using a bronze bushing that will go into a 1/2" hole I believe
  16. iwanaflattie
    iwanaflattie
    So if a 3/4 bolt
    with a 1/2" hole
    a 3/8" machined stud
    3/8" of thread could be machined,I could figure the rest..
    I messed up and drilled a 9/16" hole instead of 1/2 on the shifter arm BUT I could go hunt a 1/2 on 5/8 sleeve to weld between...
    IMG_20200601_153731.jpg IMG_20200601_153615.jpg IMG_20200601_144207.jpg IMG_20200601_144143.jpg IMG_20200601_153752.jpg IMG_20200601_144225.jpg IMG_20200601_153817.jpg IMG_20200601_153941.jpg
  17. continentaljohn
    continentaljohn
    image.jpg Is this it? I can machine the .375 shaft larger if you can set a larger bushing to fit your .562 9/16 hole in the arm.
    46international likes this.
  18. Boneyard51
    Boneyard51
    Missing the location of the 1/2 inch hole, but I guess in this case close would count.
    Bones
  19. iwanaflattie
    iwanaflattie
    That would work..the next bushing size would be 1/2 on 5/8?
  20. 1946caddy
    1946caddy
    from washington
    Get a piece of round stock that's the correct O.D. and turn your bad shaft down to .250 O.D. and drill a hole in the round stock that is .251 I.D and slip it over the shaft and weld the end after matching the length.
  21. iwanaflattie
    iwanaflattie
    I would if I had a lathe
  22. 1946caddy
    1946caddy
    from washington
  23. continentaljohn
    continentaljohn
    @Boneyard51 the half inch hole is there just not drawn to scale and says .500 dia. I know this is correct to draw like this as I had industrial art drafting cl*** in 5th grade...o_O
    I can turn your old ones if you like but 1/4 inch is getting small when speed shifting :D if your going to bush it.
    I can turn down the bushing shaft to any size you want. It’s a sold piece of 3/4 inch right now . So if I turn it down to 3/8 your going to add a bushing to the bushing for the linkage arm . Now if I turn the bushing shaft to 1/2 inch your going to have to drill the linkage to 5/8. Just let me know what size to turn it down to and can machine it this evening ..
  24. iwanaflattie
    iwanaflattie
    1/2" bushing shaft would be ideal,I can drill to the next size on the arm.thank u
  25. continentaljohn
    continentaljohn
  26. Like Mr. Squirrel said,,,,,,a bench grinder will work fine after welding up the shaft .
    I have done this several times in the past,,,,on linkage for a Muncie .
    Works very similar .
    Tommy
  27. sunbeam
    sunbeam
    I think the orginal idea was the best. If you are not in a hurry I will do it no charge to help a guy out but the next month or so is a little crazy because of wheat harvest.
  28. continentaljohn
    continentaljohn
    Done but whats the size of your rods as my endmill was on just undersize and made the hole .498. I can ream it out a bit bigger if needed image.jpg
  29. iwanaflattie
    iwanaflattie
    Daaaam those are nice...
    I don't have the rods but I'm sure I can file the ends down I wouldn't worry about it..
    continentaljohn likes this.
  30. Dad gum,,,,that looks really good .
    Excellent job continental !
    Tommy
