Customs Anyone use a universal hydraulic clutch?
Discussion in 'The Hokey Ass Message Board' started by Deere boy, Aug 27, 2018.
  1. Deere boy
    Deere boy
    I'm building what could best be described as a model T speedster with a tractor engine. I'm finding hooking up the clutch linkage a nightmare, not only because of the angle of the fork lever coming out of the housing, but it also seems to pull pretty hard. Since I don't have anything else around with that type of clutch I can't really define what "pull pretty hard" means.
    Anyway has anyone used one of these universal hydraulic clutch kits and how well does it work on a tough clutch?
    https://www.ebay.com/p/Speedway-Hyd...Swing-Mount/665084259?iid=261944784120&chn=ps
  2. 54vicky
    54vicky
    used one for years on race car made my own mount worked for years no problem.***** to bleed but other than that worked as should
  3. bobss396
    bobss396
    That's Speedway's pull-slave. I used that master and their push-slave on my Ford, works great.
  4. Don’t rule out a cable. There’s a thread on here about converting to cable clutch.
  5. Deuce Daddy Don
    Deuce Daddy Don
    1961-62 Ford econoline slave cyl. works good.
  6. Turbo26T
    Turbo26T
    I used Wilwood components (Master ,Slave) connected by a S/stl flexible line ..Fab'd up a mount for the slave to mount on the T5... Works great , solved my problem
  7. 54vicky
    54vicky
    the cable is-was a very poor idea cable stretch cutting of roller wheel etc.probably meant for the occasional shifter=sunday driver
