1952-59 Ford Anyone use the kit from Butch's for a 302 swap?
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Feb 28, 2018.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. Street Freak
    Street Freak
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    As of Nov 3rd no response from Butch's so I did a resend on my own email. Sray tuned.
    welderdave562 likes this.
  4. VWJon
    VWJon
    I purchased some engine mounts from him in Feb, Called and talked to them and placed my order.
    Been my experience that alot of car guys don't use Email much...
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    For which swap ?
  6. mightysnafu
    mightysnafu
    from indiana
    I know this is an older thread, and this may not be the right place to post a question, that being said. I have a 56 town sedan, 351w/AOD swap, I was wondering if anyone could tell me what to run for trans cooler lines.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    When I did my '54 the lines I used were two 36" long 5/16" steel brake lines from Autozone just some slight bends off the transmission fittings and a straight shot along the oil pan to the B&M trans cooler which is mounted behind the grille on the splash pan,I did not run lines off of the radiator.
  8. mightysnafu
    mightysnafu
    from indiana
    Awesome thank you. Did you have to use any sort of adapter to thread them into the transmission?
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    The fittings were already in my transmission but they are not regular hardware or parts store fittings they have an internal o-ring to seal them so a visit to your Ford dealer or a local transmission shop is where you want to get those the external thread is 5/16'' tube A cooler this size is about right to mount behind the grille. https://www.ebay.com/itm/Derale-13502-Series-8000-Plate-Fin-Transmission-Cooler-Kit-13-Row/141889632859?_trkparms=aid=1110001&algo=SPLICE.SIM&ao=1&asc=61006&meid=aaf803fc31ac467cac0f3d6330e818f6&pid=100008&rk=2&rkt=12&sd=401063201101&itm=141889632859&pmt=1&noa=0&pg=2047675&_trksid=p2047675.c100008.m2219 Once you get the special case fittings take one along to match up to the brake line tubing when you buy it some 5/16" lines have metric fittings on the ends :mad::mad:
