Anyone used spacers on Radir Tri-ribs
Discussion in 'The Hokey Ass Message Board' started by oiler, Nov 27, 2012.
  1. oiler
    oiler
    Probably going to get slammed for this but I ve got Radirs for my A project and they hit the Wilson drums I've got up front.
    looks as though a 3/4 inch spacer would work along with longer Mororso studs to get me the clearance.
    Never used spacers and theres a lot of different opinions out there
    Anyone got experience or opinions here?
    Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
    I used spacers/adapters on the rear of my 4 door 32 sedan with no problems. HRP
  3. Had to use 1/2 inch billet spacers & longer screw in studs on the Wilwood Brakes to clear the SoCal drums . The 15 x 4 inch rims clear the finned aluminium drum by 1/16 of an inch! :cool:
    Photo was taken last year at the Goodguys event in Spokane, Wa
  4. Paulie9fingers
    Paulie9fingers
    If you use a good quality billet spacer with holes that fit the studs you will be just fine, do not use the old Mr Gaskets with the big alongated slots. Also if you need a bunch of spacer you can look into billet adapters but I think the thinnest you can go there is like an inch and a quarter.
