Technical anyone using a stud girdle with Corvette valve covers?
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Mar 6, 2017.
  1. henryj1951
    henryj1951
    from USA
    a lot of the NEW ones have extra room under there now days
    mad mikey likes this.
  2. henryj1951
    henryj1951
    from USA
    Call him he just might accommodate yo9u woith 7* ones
    ha spelling 101 you (with out the 9)...lol
  3. falcongeorge
    falcongeorge
    from BC
    another thing, I am not running aftermarket heads on this, I am running angle milled 461's, you are USUALLY ok cutting them to 1.55, but I have heard of the spring seats in camel bumps cracking after a while when they are cut for 1.55's. Sometimes its fine sometimes not, probably depends on core shift. I'd rather not chance it if I don't have to.
  4. falcongeorge
    falcongeorge
    from BC
    Honestly I prefer new springs.
    mad mikey and henryj1951 like this.
  5. henryj1951
    henryj1951
    from USA
    Thought he listed as NEW
  6. mad mikey
    mad mikey
    For the price Summit has on the K-Ms, I would pull the trigger.
    henryj1951 likes this.
  7. henryj1951
    henryj1951
    from USA
    the 461's if/when cut do slice into the water ,,, ya MUST cut above with shims in place / in the pocket.
  8. falcongeorge
    falcongeorge
    from BC
    Yea, but I got a 40 year ac***ulation of ol' **** I gotta use up...:eek::D
  9. henryj1951
    henryj1951
    from USA
  10. falcongeorge
    falcongeorge
    from BC
    Yes, I drop a .030 shim on the seat. But even if you don't actually hit water when you cut them, they sometimes crack right in the corner of the radius after you use them for a while, which is big pain in the *** when it happens after you have 40-50 hrs of grinding in them! I've run 1.55's in camel bumps, but I prefer not to if I don't have to.
    henryj1951 and mad mikey like this.
  11. falcongeorge
    falcongeorge
    from BC
    I had to look again. Holy ****, you are right! I just ***umed he was selling used stuff, $150 for new PAC springs and manley ***aniums is CHEAP! I will look into that, thanks for the tip! Man, that's really cheap!
  12. henryj1951
    henryj1951
    from USA
    461's on the OUTSIDE corners were the worst..
    we just furnace welded them and jump in like a beaver cutin em.
    Edit ALL the spring pockets.
  13. falcongeorge
    falcongeorge
    from BC
    Yup, that's where they would crack if they did. Where did you work? Were you at CHA or something?
  14. henryj1951
    henryj1951
    from USA
    Its KQQL its a HAMB thing....
    I'm down to MOSTLY doing some BS fancy painting(nobody EVER wants to pay you what your worth) AND valve work, for the PQQR stock / drag car boys,
    I'm retired so i can do, or NOT do...lol
    falcongeorge likes this.
  15. falcongeorge
    falcongeorge
    from BC
    Man, you know, I was just thinking, if you REALLY want to know something about getting serious with camel bumps, theres a pretty good wealth of info on this thread.
  16. henryj1951
    henryj1951
    from USA
    WE'RE like the govt. we're here to help.
  17. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    With all that info, which some things I have not tried, and my "pocket " was more accomidating, I would go with your choice.. some things aren't meant to chance, even though you could....... I think the ( your ) spring choice is a good one, and will suffice with the #'s, and diameters. Saving the pocket, covering the cam, and so on.... Rock On!
    falcongeorge and henryj1951 like this.
  18. henryj1951
    henryj1951
    from USA
    1.6 's big block O.D.'s in some 461's on a 283 back in 1972.
    Life is a bit easier buying stuff (gotta love that word stuff) right out a the box these days.
  19. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I was still ******* myself randomly, and my 461/462 info didn't arrive until a lot later!:eek:. But glad you did it, and have the t-shirt! ;)
  20. henryj1951
    henryj1951
    from USA
    and angle milling those same heads , (none were available to BUY in 1972)after plugging the cooling holes, then milling them down to next to nothing , there was about 1/4 inch left tween top of bolt hole and surface.
  21. falcongeorge
    falcongeorge
    from BC
    YIKES!!!:eek::D
  22. Tickety Boo
    Tickety Boo
    from Wisconsin
    Wow just got back on :)
    Thanks for all the info. ( a lot of smart guys here ):cool:
    Have 2234002A Top-Proline 220 heads with a Howards mech. roller cam that Compe***ion Products recommended about 10 years ago. (Heads are cut for 1.437 dia springs)
    Current valve springs are Howard 98441 installed @ 1.750 with closed pressure @ 175 lb
    open pressure is 400 lb @ 1.150
    Looking for a 1.437 valve spring / retainer pkg with installed height @ 1.850 so there may be enough room for
    .681 lift using 1.65 Howard rockers.
    Freshened the engine, bolted the heads back on yesterday.
    Norb
    saltflats and henryj1951 like this.
  23. falcongeorge
    falcongeorge
    from BC
    I was washing Brooks pistons and rods and pushing a broom around Bob Crosbies shop at that time. And watching him screw Booth-Arons heads onto MP and gas cl*** motors...I saw some pretty trick **** in those days.;)
  24. falcongeorge
    falcongeorge
    from BC
    Norb, what are you shifting it at with those springs? Do they last good?
  25. Tickety Boo
    Tickety Boo
    from Wisconsin
    Running a glide shifting @ 6900 rpm, going through the lights @ 6300 rpms
    Never had any trouble with them, I should replace them any way 10 years old.
    saltflats likes this.
  26. falcongeorge
    falcongeorge
    from BC
    Thanks Norb. 10 years on the same springs! Hell, nothing wrong with THAT!:D
  27. saltflats
    saltflats
    from Missouri
    Norb with those heads you should have no problem cutting the spring seat for a better spring package.
  28. Tickety Boo
    Tickety Boo
    from Wisconsin
    After larger springs installed, no room would be left to get a socket on one head bolt.
    ( 1st bolt in the torque sequence )
    All ready have to use a skinny 3/8 drive socket to jam between the springs.
  29. cali-chopper
    cali-chopper
    from belmont ca
  30. Tickety Boo
    Tickety Boo
    from Wisconsin
