Anyone with a Brookville body run into this problem?
Discussion in 'The Hokey Ass Message Board' started by Groovybaby6, Jul 4, 2012.
  1. Groovybaby6
    Groovybaby6
    from Denver
    The LH top Quarter panel of the '32 Brookville roadster body looks like this, tons of stretch marks from stamping.
    I was able to file and sand them out to get it perfectly smooth but man!
    That was a ton of work!
  2. lowsquire
    lowsquire
    from Austin, TX
    Yep mine looked the same.
    you want bad stretch waves? Try painting a rootlieb 32 hood top gloss black..ugh.
  3. Yes, this was posted a year or two ago. You are not alone!
  4. Groovybaby6
    Groovybaby6
    from Denver
    I'm painting this '32 black, that's why I HAD to sand out all those imperfections.
    Oddly, the RH side looked almost perfect, just minor filing & sand was needed.
  5. n.z.rodder
    n.z.rodder
    You should've started with a dented rusty one, so you wouldn't have to deal to the stretch marks.
    Scotty.
  6. beater32
    beater32
    If that's your biggest moan with bodywork.....you got it easy.!
  7. Lurker McGurk
    Lurker McGurk
    from next door
    uugh, stretch marks,:eek: NObody wants to see those.
  8. Same here....
    Rat
  9. TerrytheK
    TerrytheK
    X2. Not real sure you're going to get much sympathy around here. Bodywork is part of building a car.
  10. big duece
    big duece
    from kansas
    I'll trade you problems, I dont HAVE a body yet to ***** about! If I had a gl*** one, then we could trade and all your stretch problems would be gone.
  11. Dale Fairfax
    Dale Fairfax
    That's (or was) a common problem in any automotive stamping plant when "deep drawing" sheet metal. The quality of the steel and the condition of the die has to be spot on. In the high volume shops, the first step toward correction was to to try steel from a different vendor (At Chevrolet, we had steel from as many as 5 different mills for the same panel-all of it the highest quality we could buy but there were still variations from mill to mill and-worse, mill run to to mill run). If that didn't work, the die was turned over to a die spotter who would often work for days on the blankholder. Often, he'd fix the problem only to have it recurr when steel from another vendor was fed into the die. The high volume shop at least had the liberty of wasting several blanks during the corrective procedure and once back in production could produce at 300 per hour.
    Brookville is a completely different world: low volume, probably single sourced on steel, marginal die design, using the same press for most panels.
  12. aaggie
    aaggie
    I would bet the original Ford stampings were just as bad. I've seen old pictures of workers fixing imperfections before they went to paint and there were lots of them.
  13. Groovybaby6
    Groovybaby6
    from Denver
    I was wondering that when I was working on it, if the original bodies had those problems in the quarters.
    This body actually had stretch marks all over it and low spots and high spots and tons of scratches to be sanded out.
    ironically, people say all the time, "Brookville bodies, just prime and paint". In reality, it's more like sand for 30 hours, then prime.
  14. gearheadbill
    gearheadbill
    That's one of the reasons why they invented louvers.
  15. ntxcustoms
    ntxcustoms
    from dfw
    Those ripples are a prime spot for using (or learning) a shrinking disk.
  16. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Factorys used lead to smooth out the imperfections!!
  17. Great,
    now instead of thin stretch mark ripples you have filed & sanded them into even thinner spots. Shirinking disk
  18. joel
    joel
    thank You! Alot of the body work on my 40 is replacing thin metal from not enough metal finishing and too much filing/grinding.
  19. Fogger
    Fogger
    I built a Brookville '32 roadster, low 200s body number, and to get it ready for black spent over 100 hours with a body man chiseling the reveal lines, which were soft, and straightening the flat panels. It was worth the effort and money spent. Considering the low production numbers produced by Brookville their products are great. But no one should think they can just prime and paint, like any project they need attention.
  20. need louvers ?
    need louvers ?
    Absolutely! And I recomend lots of them too!:D Though I have to say, the last couple of rootlieb '32 hoods I've done were VERY nice.
  21. tiquer
    tiquer
    I have used Rootlieb hoods on many Model A`s and found them very high quality and most cases fit better than most original hoods do.
  22. outlaw256
    outlaw256
    man that aint no problem.i would rather shrink all that **** than try to rebuild a old henry.i looked at a old body the other day.not much left to work let alone build.body work and engine building , thats what it takes to do what we do.so just look at it like thats your dues for gettin this thing on the road.
  23. Ok let's see..... There's somewhat close to 0.040 metal thickness there.
    The if the ripples were a full metal thickness off you would have sanded holes, right ?
    If you filled them at a full metal thickness 0.040 would be too thick of filler for you ? ?
    And if the ripples were 0.02 deep, 0.02 is too much filler but metal thickness of 0.02 is ok ?
    I really don't get it.
  24. 1/2done
    1/2done
    from Ohio
    I think I'd s**** that body, way too much metal finishing.
  25. A friend told me Rootlieb is German for "don't fit"
  26. moefuzz
    moefuzz
    My '31 roadster required several hundred hours of bumping/color/wet sanding to turn it into a sheet of gl***.
    Problems with spot welds and general body dings/imperfections, body panels not lining up as
    in the reveal at the doors and cowl did not match size and wasn't in alignment. Rear tail pan
    was so poorly tig welded that it was cracked and starting to separate. '32 grille shell and
    Vintique insert would not fit without rubbing of the paint around the inside of the shell.
    It was delicate work opening up the inner radius of the shell so that the insert looked good as
    well as didn't rub/grind.
    All in all, much nicer than working on rusted/banged/missing parts. Have and Will do it again.
  27. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    On Boyds Hot Rod show I watched them mud the whole body on a brand new Brookville Roadster to get it straight!!!!
  28. outlaw256
    outlaw256
    yea but thats not body work.to me thats just a lazy mans way out.but i have done it to a few bike tanks.aint now way of getting inside to work the metal.
  29. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Hot Rods take hard work to make look even better than they are when you get them. This hard work pays off the 1st time you get behind the wheel and get the 1st chip in the paint or bugs in the radiator.
    If someone wants perfection which these and Briggs bodies from the get go never were,then some hard work is needed. Have you ever seen a Bugatti,Ferrari or Alpha in the raw? That's work, It takes weeks to make them look straight.
    I think I'll take the stretch lines in the 1/4's, Then at least then I'd know that I'm looking at nothing but metal and 0 filler.
    Your work looks great and I'm sure that it's gonna make a very kool Hot Rod.
