1952-59 Ford AOD compatible Speedometer cable for 1956 Ford Victoria
Discussion in 'Off Topic Hot Rods & Customs' started by artooks, Mar 29, 2024.
  1. artooks
    artooks
    Hi,
    I have just purchased a 1956 Ford speedometer cable, but I think I did it wrong and need some help on that. As I have an AOD speedometer in my 1956 Ford Victoria I need to buy a compatible speedometer cable, the one that I purchased below is just a reproduction of the original cable.
    https://www.ebay.com/itm/201590937378
    So I guess this does not fit my AOD ******, am I correct, if so which cable should I purchase, I really need some help here.
    I also need to determine the speedometer gear, how do I calculate it ?
  2. 51504bat
    51504bat
  3. artooks
    artooks
  4. artooks
    artooks
  5. Paul2748
    Paul2748
    The trans end of the cable you mentioned firstwas last used in 56. In 57, the trans end like you showed later on was the one used starting in 57. Weather it fits the AOD I am not sure,
  6. Dos Cincos
    Dos Cincos
  7. artooks
    artooks
  8. Dos Cincos
    Dos Cincos
    I have a 56 dash with original 56 speedo and an AOD from 87.
  9. artooks
    artooks
    Thanks this really helps me out. By the way I also I also need a speedometer gear for my AOD.
    The tire size: 215/70-15
    Ring and Pinion Ratio: 3.89:1
    The only thing that I do not know is the exact tooth count on the inside gear but I know that it is either 7 or 8
  10. evintho
    evintho
    I have a '54 with original speedo and an AOD out of a '93 Mustang. I'm using the Mustang's original speedo cable. It inserts right into the square pin inside the speedo. There're threads on the speedo but none on the cable end so, I just secured it with a small hose clamp. Not going anywhere! The cable is about 6" too long but that's just taken up by a half loop underneath the car.
    down-the-road and JeffB2 like this.
