AOD ford trans ???
Discussion in 'The Hokey Ass Message Board' started by Cannibal, Aug 3, 2005.
  1. Cannibal
    Cannibal
    Are there any years and models better or ones to avoid.
    My Dad has a 94 Mustang with an AODE and he's had all kinds of problems.
    Anyone know of a good website for model ID.
    I want to hook this up to a healthy 302.
    Also what rear gears work well with this tranny.
    Thanks
  2. Fat Hack
    Fat Hack
    from Detroit
    Look for the early AODs that weren't electronically controlled. They came in lots of mundane cars like early-mid 80s Crown Victorias and stuff. They use a TV (Throttle Valve) cable in place of a vacuum modulator and work pretty good for an overdrive auto.
    3.55 to 4.11 gears will compliment an AOD real well in most hot rods.
  3. chopndrop
    chopndrop
    Ford converted to the electronic type around 1990 or 91, not exactly sure. I have heard that you can get a stand alone computer for the later ones if you go that route. You have to get the cable just right or you can screw the tranny fast, so I hear anyway. I'm thinking about using a 302/AOD in my 56.
  4. TexasHardcore
    TexasHardcore
    from Austin-ish
    yeah the AODE's suck ass. Avoid them at all costs.
    The AOD's suck too, but they can be built to handle high horsepower levels.
    I went through 5, yes FIVE, AOD's in my old Mustang. It ran high 11's and was a daily driver though. It had a 3500 RPM Stall Converter, Level 10 HD Gear kit, Beefed Clutch Packs, and a B&M Shift Improver kit. Worked great with 4.10 gears, even on the highway.
    I think I'll run my spare AOD in my next project since it's not going to be over 250hp. Any more than 250 and I'd just swap over to a C4 to save the costs of rebuilding the AOD several times.
  5. TINGLER
    TINGLER
    I have TWO Ford trannys here at my place...one came from a T-bird, one from a Cougar. Both had 302's. IF ANYONE WANTS THESE, COME AND GET THEM. They are setting outside now and are FREE for the taking.
    If someone can use them, they are YOURS!
    I don't know anything about automatics, so I swapped them out for standard trannies.
    I guess I'm not adding anything to the post, but just giving a heads up for two transmissions for FREE.
    TINGLER
  6. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    almost positive its pre 92 to go with.
  7. Alfster
    Alfster
    So, how do you tell which is which??
  8. Fat Hack
    Fat Hack
    from Detroit
    The early AODs will have no wiring plugs on them anywhere. They just have a TV cable.
  9. BigChief
    BigChief
    Yeah, but what kind of reception do they get? :)
    heh, heh, heh....
  10. Crosley
    Crosley
    from Aridzona
    Both AOD & the AODE have an electrical connector on them.
    The AODE has a connector on the passenger side , kinda a "D" shape , several connector pins in it.
    The AOD has a connector on the drivers side at the shift arm... it is a neutral safety / back up light switch..... NO electrical connector on the passenger side.
    The cross over years is 1992 & 1993 for the Ford AOD & AODE.... either tranny can be in a vehicle .......Look for the connectors!
    I hope the visual aids ( photos) appear....
    hope this post helps
  11. Da' Bomb
    Da' Bomb
    Stick with pre '92....Follow the Lokar instructions for pressure settings and it'll live.....up to about 300h.p.
    Pat
  12. Cannibal
    Cannibal
    Thanks guys .
    I`m looking at putting in a 351w with 250 HP 350 torque.
    What torque converters have you used?
    The car will be used for light towing and lots of hiway travel.
  13. These fellows have done an AOD swap in early Mustangs. Maybe not specifically what you want but there looks to be good general info on this site
    http://www.themustangshop.com/
    Go to the "how to's
    Stu
  14. Cannibal
    Cannibal
    Thanks for the link a very good tech article.
  15. kentucky
    kentucky
    Make that three FREE AOD's. I have one here in central KY for free too! Just give me a hand taking it off the 302. It's out of an 82 Continental, and as with most free things no warranty and you get what you pay for:eek: :D But seriously it would be a good builder, it's "supposed" to be good but...:confused:
  16. Alfster
    Alfster
  17. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    I HAVE TO AGREE,
    WE ARE PUTTING A PRE 92 AOD FROM A VAN BEHIND MY '50 FLATHEAD WITH AN ADAPTER FROM SPEEDWAY MOTORS. (NEEDED THE AOD FOR LOOOOONG TRIPS)
  18. mikeyboy
    mikeyboy
    aod will live under high horsepower levels if built correctly...police input shaft, other internal mods...TV cable adjustment is critical...you can burn one up in 20 miles (do not ask me how i know this). Don't have all the answers, however a good ford trans guy can make one stand up to just about anything
  19. Cannibal
    Cannibal
  20. lgh1157
    lgh1157
    I may be picking up a AOD out of a 89-91 Mustang GT.
    Is this AOD electronic ?
    Reading back on this post, its sounds like '92-'93 was when they went electronic.
    Can someone confirm this
    L
  21. michaelthe9
    michaelthe9
    Get one with out the "E" on the end. I'm installing an AOD with out the "E". There are some rebuild kits out there that adjust for a more possitive shift.
    Check out www.transonline.com and www.atsgmiami.com. I recommend shift kit SK AOD-H to correct some issues and the 1980-91 AOD (010-203) Tech Manual from ATSG if you are going to rebuild it yourself.
    Good luck.
  22. michaelthe9
    michaelthe9
    Forgot to mention that mine is out of an '88 Lincoln Mark VII LSC.
    Michael
  23. lgh1157
    lgh1157
    Im going with a AOD
    All i wanna know is :
    Is a AOD from a 89-91 electronic ?
    I dont want electronic and before i buy this tranny i wanna make sure of that.
    L
  24. oldcarfart
    oldcarfart
    for your application use the stock converter.
  25. mustangsix
    mustangsix
    The 89-91 is not electronically controlled. It MUST have a TV linkage or cable properly hooked up, though.
  26. lgh1157
    lgh1157
    Thank you M6 !!!!!
    L
  27. mustangsix
    mustangsix
    Make sure you also get the plug for the neutral safety/backup light switch.
  28. Nads
    Nads
    from Hypocrisy
    What's up John?
    I feel like killing something.
  29. bwiencek
    bwiencek
    Actually they do - it's just for the neutral safety switch and backup lights.
    Try to get a '92 as they had the best clutch pack setup of all the trannys. There is also the ability to swap the E4OD low gear set into the AOD (Which I'm planning to do for my P/U) - this lowers first gear 15-18% (if I recall - don't have the number in front right now) - really wakes up the first gear acceleration.
  30. burndup
    burndup
    from Norco, CA
    I'm new to these trans too, but I have one in the garage... What is it about the TV cable misadjustment that will kill them?
