Technical AOD Transmission Help
Discussion in 'The Hokey Ass Message Board' started by Rich Richardson, Jan 31, 2021.
  1. Kevin Ardinger
    Kevin Ardinger
    Also, there is a spring on the levers inside the trans that preloads the throttle valve. You may be fighting that. Disconnect the cable and push the lever all the way off. See what the pressure is.
  2. southcross2631
    southcross2631
    I always install a B&M shift kit in all of my AOD installs. Sounds like a valve body gasket leak.
  3. okiedokie
    okiedokie
    from Ok
    I will add that on my first AOD I drove it around a few blocks several times sorting it out. Did not hurt it a bit. Have you checked your fluid level warm and idling in park?
