Technical AOD Transmission installation tips in a 1954 Ford F100
Discussion in 'The Hokey Ass Message Board' started by Mlacelle, Sep 30, 2018.
  1. Mlacelle
    Mlacelle
    Has anyone put an AOD transmission into a 1954 F100 frame. Do I need to remove the current crossmember mounting brace or can I use it and modify it to Mount the new aod transmission?
    Sent from my LGLS992 using The H.A.M.B. mobile app
  2. FrozenMerc
    FrozenMerc
    At a minimum, you will have to modify it. The AOD mount pad is quite a bit further back then most earlier transmissions due to the OD planetary ge****t. Mock it up and start measuring. See if it is easier to modify the existing cross member, or build a new one.
  3. Mlacelle
    Mlacelle
    Thanks. I will be mocking entire frame up this winter
