AOD Woes
Discussion in 'The Hokey Ass Message Board' started by tcoupekyle, May 20, 2008.
  1. tcoupekyle
    tcoupekyle
    I just bought an AOD automatic. The transmission guy I bought it from says that it has some kind of B&M shift kit in it and it does not need a TV cable. Can this be true?? Also can I use a regular ratchet shifter just to put the AOD in drive or do I have to buy one of the special ones??
  2. rstanberry
    rstanberry
    from terrell tx
    Better check with B&M. I'm not aware of anything like this. TCI i think has announced a valve body to just use the tv to set the shift points.Sounds like a fried trans waiting to happen.
  3. tjm73
    tjm73
    NOT TRUE.
    The AOD absolutely requires a TV cable. And it must be set properly. Lokar (I think) makes what you need. If you don't run it, you will burn it up.
  4. tcoupekyle
    tcoupekyle
    thanks what about the shifter
  5. tjm73
    tjm73
    Hurst and B&M both make AOD specific adapters that let their ratchet shfters work. So you are good on that front.
