Technical Appleton 552 Switch
Discussion in 'Traditional Customs' started by Chop50, Apr 22, 2023.
  1. Chop50
    Chop50
    Hi All,
    These are Appleton 552 handles. Where are the switches operated from? They different than the 112 switch?
    Also, when locating the mounts on the A-pillars, driver side has the wiring harness going up through it. How do folks manage that?
    Thanks, Steve
  2. The wire in the "A" pillar is for the dome light, drill pilot hole on the inside and outside, then drill the larger hole the same way then go all the way thru the pillar. If you hit the wire , just run a new one on the floor and up the "B" pillar to the dome light.
  3. Chop50
    Chop50
    Did the rear harness originally go along the floor? I ran the entire rear harness up through the A pillar and along he roof to the trunk
  4. abe lugo
    abe lugo
    Look up polykingcustompolymers on IG. He is a really nice guy and can help you out. He started remaking the proper mount brackets if you need them.
    On 552 I thought the switch was a push ****on in the end.
    51 mercules likes this.
  5. 51 mercules
    51 mercules
    I"ve had appleton 552s with at least 3 different switches.****on at the end, a twist one at the end and the switch on the side of the handle.
  6. custom_lettering
    custom_lettering
    from Wall, NJ
    X2 polykingcustompolymers
    Great guy, helped with mine.
  7. Chop50
    Chop50
    Tried reaching through the forum with no luck, I will try through IG
