Technical *** APRIL 2016 BANGER MEET - DON'T BE FOOLED BY SUBSTITUTES ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2016.
  1. V4F
    V4F
    from middle ca.
    throttle linkage for my burns intake ***** make one , not all that hard .
    whats wrong with this : girls kissing girls & I set here all puckered up & no girl to kiss ?
  2. winduptoy
    winduptoy
    think you might just be spending too much time on the interweb it will make you think things that are not
    Go fourth into the garage and wrench, polish on banger and then go four a drive. All such things will seem so un important then.
    I'm going to do the same
    four now, winduptoy
  3. wrong forum...........
  4. V4F
    V4F
    from middle ca.
    lol just a passing thought . to old to handle it any more . got to have a sense of humor ............ steve
    as they say "be open minded - your brains wont fall out"
    apparently my humor is not apparent ........... sorry
  5. jim1932
    jim1932
    1. Ford A and B speed
    IMG_2181.JPG what is best way to soak this crud out with? No I don't have blasting equipement.
  6. V4F
    V4F
    from middle ca.
    I understand white vinegar will remove rust etc
  7. orangeamcs
    orangeamcs
    You could try the trick w baking soda and a battery charger maybe
  8. jim1932
    jim1932
    it not rust, its varnish. soaked it for several days in evaporust
  9. denis4x4
    denis4x4
    from Colorado
    A (costly) comedy of errors! Last year I did the Dirt Drags, Speedster Reunion, the Georgetown Hill Climb and a lot of local tours. At Georgetown, everything quit at the first hairpin going up the hill. Ended up putting it back on the trailer and headed back to Durango. Before loading it up, checked the spark (weak) and then found that the right rear brake was locked up. There were enough teeth on the fiber timing gear to turn the rotor when we checked it. However, the next time we checked, no spark and the rotor wasn't turning. Ended up replacing the Petronix module (unnecessary) new battery (probably unnecessary) new alternator, coil and timing gear (Dan McEachern). After replacing the Lokar cables, found out there is a lifetime guarantee! Problem was not using the stock rubber nipples on the backing plate ($4 a pair from Sacramento Vintage). Got everything back together with a new pan gasket and head gasket. Also replaced the Stromberg intakes with a Weber manifold. Fired up the first time I pulled the starter and is running great.
    Bottom line; there is a trouble shooting sequence I didn't follow and it ended up costing me money I didn't need to spend.
    Garagekulture13 likes this.
  10. Try soaking that gunk in kerosene or diesel. Then get after it with a scrapper and wire brush
  11. colinsmithson
    colinsmithson
    Jim back in the day I used to clean small parts like that by putting them in a jar 1/2 full of sand and fine gravel and while sitting and having a drink at the end of the day or watching tv shake the jar
    Now you can laugh but it works
  12. Bluto
    Bluto
    Rear bumper of my truck Steve
    Crazydaddyo likes this.
  13. V4F
    V4F
    from middle ca.
    maybe I need one to warn people !
    hows jimski ?
  14. V4F
    V4F
    from middle ca.
    on cleaning the part .... maybe try PB BLASTER
  15. Bluto
    Bluto
    If it's shellac you can soften it with alcohol and then some rubbing
  16. ebtm3
    ebtm3
    Easy-Off spray oven cleaner?
  17. ebtm3
    ebtm3
    How many over there can read it though?
  18. Bluto
    Bluto
    Only the one's that laugh and honk madly!
    Mental health is a universal problem.
    G Baese and Jiminy like this.
    Ok guys back on topic[emoji846]
    Got the new front axle, cross shaft, and rear backing plates installed. Hopefully after work in the evenings this week I'll be able to get it buttoned up and back on the road.
  20. The Brown Sound
    The Brown Sound
    from Maryland
    I picked up a running banger last week and started tearing it down to prepare for paint. Does this valve guide need to be replaced? ImageUploadedByH.A.M.B.1460390358.127452.jpg
  21. orangeamcs
    orangeamcs
    I'm getting ready to install a lightened flywheel in my b motor. I got one done to b specs then lightened. Anything I need to do special when swapping or is it just a remove and replace scenario
  22. Bluto
    Bluto
    Get your flywheel balanced
    Yes , Valve guides are not self-healing.
    hotrodfil likes this.
  23. I resemble that remark............
  24. Specialty Ford parts in Rosemead Ca make most a that stuff
  25. Oven cleaner, try a sample first. I'm cleaning some rusty Kelsey's in a tub of white vinegar 2 days a side the hose off then brush rust off. But for crud, old grease, or oil and dirt buildup I use oven cleaner. Not on paint just metal, might harm pot metal or Al. For pot metal I boil in water with some TSP.
  26. jim1932
    jim1932
    Who did you get to do it?
  27. colinsmithson
    colinsmithson
    As said balance is a big thing and use good bolts many of us use 6 bolts instead of 4 just to be safe
  28. Bluto
    Bluto
    With six bolts there are 50% more projectiles coming thru floor when the unbalanced flywheel comes apart! Or maybe it does stay with the end of the broken cranks rear main and flange. If you have no idea how careful the guy machined the flywheel was you should balance the flywheel and clutch cover. The disc with take care of itself since it lands in a different spot overtime you shift
    I have seen flywheels come apart it's not fun
  29. This one stayed on the crankshaft, the pressure plate dismantled itself.
  30. Bluto
    Bluto
    I think people forget the stresses involved. Aren't you required to have a bullet-proof can?
    All of you please look at this and remember that could be your foot!
    FUN IS FUN....... AND LOUD BANGING NOISES ARE NOT!!!
    Next Wednesday they remove the other cataract
