Technical ***April 2022 Banger Meet Thread - Don't Be Fooled by 5***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2022.
  1. Jiminy
    Jiminy
    Link to previous month: March 2022
    Coming Events: (PM Jiminy with additions/corrections)
    September 18 Auburn, CA NorCal F.A.S.T. Fall Hill Climb
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. just lurking and bolting motor back into car
    Crazydaddyo, Phil Damon and winduptoy like this.
  3. denis4x4
    denis4x4
    from Colorado
    Back in Colorado after filling my old F-150 with $6 a gallon fuel in California earlier this week.
    winduptoy likes this.
  4. Steves46
    Steves46
    from Florida
    Will be installing a leak less Water Pump this weekend. Hopefully it will hold-up to its name!
  5. noboD
    noboD
    Can't be April, it's snowing.
    chryslerfan55 and winduptoy like this.
  6. low down A
    low down A
    yea that is our april fool woke up this morning to 25 degrees temp and 3 inches of snow on the ground
  7. Ha!!
    drove past the petrol station and reg was $6.20/Gal... first thing I thought of was April Fools!!
    We are screwed....
    J
  8. winduptoy
    winduptoy
    Crossed over to the dark side...
    Sold all my bangers
    Jet96 and G Baese like this.
  9. Russ B
    Russ B
    Hope to get a good start on my Burtz block this month. I have almost all parts now, all for the short block.
  10. Happy April Fools!
    Spent a few hours at work mocking this up. I have no intent on running this, but it might make enough interest to cast one or two intakes!
  11. V4F
    V4F
    from middle ca.
    no foolin nothin new here
  12. Checking in, picked up a English model A engine for parts, they are about 122 cu inch,
    0FC3B2E6-B91D-4C02-88CF-5EEECA6521E2.jpeg 360C16D8-E0E4-4FE2-AF43-B9976F295D68.jpeg 2FB8A824-6B64-4028-AA88-2C34EAF5F3BD.jpeg
    stillrunners, Jet96, Old Dawg and 3 others like this.
  13. Midnight Rider
    Midnight Rider
    from Australia
    Checking in, the days are getting shorter down here.
  14. barrnone50
    barrnone50
    from texas
    Checking In, Major Leak Checked rear main .0015, drain pipe clear. New pan gaskets. Still heavy leak. Did compression check 1-120 2-0 4-120 3-120. Should have done a Leak down test before I took the head off.
    Back to square one. Rings looked good. I guess check cylinders and re ring and valves. Check all lower end
    let the fun begin..:)
    Jet96, winduptoy and Outback like this.
  15. Outback
    Outback
    from NE Vic, Oz
    Gday folks, Today I did a 6 hr 300 odd mile round trip to drop off the last of a load of AA truck parts which is being relayed to Alice Springs - in the center of Aus - 1500 miles from here. In exchange I'll get some A model bits back. Some rough roadster parts & some wheels. Looking forward to seeing them, its taken some mucking around & humbugging some folks but it won't owe me all that much & helps the old fella out. Win win I hope.
    I have also started again to get my A RPU progressed, I got talked into putting it into a beach race over here mid May. It's the kind of motorvation I need to get it going....
    Here's the drawn out build thread.
    www.jalopyjournal.com/forum/threads/back-in-a-banger.1092051/
  16. Outback
    Outback
    from NE Vic, Oz
  17. winduptoy
    winduptoy
    In therapy, withdrawals
    Jet96 likes this.
  18. V4F
    V4F
    from middle ca.
    been running a leak less pump for years ............ no trouble ...... steve
    Steves46 likes this.
  19. Tribalmonkey
    Tribalmonkey
    Checking in from Maryland. Looking forward to the warmer weather!
    lothiandon1940 likes this.
  20. V4F
    V4F
    from middle ca.
    is anyone here running a "super bell" axle ? would like to talk to someone ........... steve
  21. it’s not a Y motor, it’s a Model A motor, everything is normal Model A , just a small bore. I believe they were built so you paid less road tax. This one is probably out of a truck, it has the AA bellhousing, how it got here to Switzerland, I don’t know, possibly it was in a local/ homebuilt tractor. I got from a farmer, he said he bought it about ten years ago, and has since been sitting in the hayshed.
    Jet96 and chryslerfan55 like this.
  22. Outback
    Outback
    from NE Vic, Oz
    Wow, I didn't know they existed! What carb do they use?
  23. Not sure, there was no carb on the motor when I got it, it does have a Bosch distributor, but it’s needs a complete rebuild, the front pulley is also cast iron and smaller than the std model A
    The Ford garage website has quite a lot of info on them
  24. CGkidd
    CGkidd
    Checking in. Been awhile but my sports coupe has a new motor with iron miller head. Also mitchell transmission. Rearend is coming out soon to make way for a quick change.
    Outback and chryslerfan55 like this.
  25. Fabber McGee
    Fabber McGee
    Good looking mag drive. Who made it?
  26. Pity the head is smashed - that’s a factory high compression head.
    chryslerfan55 and skip65 like this.
  27. Most likely a Charlie Yapp / Secrets of Speed timing cover. I believe they use a VW Distributor or Magneto.
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    All you need is a donor head, a little patience... and a lot of Lock-n-Stich pins!
    Old Dawg, Outback and skip65 like this.
  29. raaf
    raaf
    I'm about ready to pull the trigger on my engine build, probably Burtz + Serr Miller.
    What do you all recommend for driveline? If I go T5, do I try to keep stock A axles and try to marry those to something like a Halibrand 101? Do you recommend open or closed? What's everyone running?
    Sorry the only thing I have to contribute is questions, but I'm thankful for any insight this group can offer.
    Outback likes this.
  30. CGkidd
    CGkidd
    Correct it is a Charlie Yapp piece. With vw mag
