Technical ***April 2022 Banger Meet Thread - Don't Be Fooled by 5***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2022.
  1. raaf
    raaf
    Hey @CGkidd - did we go to the HAMB chop together circa 700 AD??!!
  2. trikejunkie
    trikejunkie
    from Scotland
    Hi , I am not an expert in this by any means but my driveline is 1932 B engine,1932 gearbox with 1939 gears inside,A torque tube and a Pacific Quick Change centre section in to a standard A axle .I am hoping this will give a nice reliable driving car using all traditional hot rod parts
  3. Dustyp489
    Dustyp489
    Checking in, having the building redone were my A is , hope to get back to it in a week or two.
  4. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Pushing 90 here today...
  5. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    sounds stellar... I have been wanting to swap to a 32-39 box myself lately...
  6. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Checking in...
    Put 100 miles on it in the last week, got my fueling issue fixed... 1/4" to 3/8" now makes gravity work stellar...
    Rolled 70 without issues now... Need to tighten up the steering box a smidge to push farther than 70 at this point but she does it and pulls strong... Car seems to really feel planted and dialed in at 65 though... But some of that is probably the factory caster setting and bias ply tires. Best upgrade to date is the Mallory YA dizzy...
    Went to Coffee and Cars this last Sunday, haven't been in years, remembered why but made alot of people smile and blow by looking at the corvette boys etc... So spreading the gospel I guess you could say...
    Then decided to hit a nice little area for a pic on the way home...
  7. trikejunkie
    trikejunkie
    from Scotland
    I forgot to add that I have a Thomas head, Equaliser inlet,2x81 strombergs and a pair of Paul Yapp Y exhaust manifolds ............any idea how nippy it will be?
  8. 29 Speedster
    29 Speedster
    from Colorado
    Our Speedster with similar set-up ( B Motor, Thomas 7:1 Head, Thomas Intake with 2 81’s, and custom header) has 79 HP on a Chassis Dyno.
    GuyW, Super88, v8flat44 and 7 others like this.
  9. Jet96
    Jet96
    from WY
    Checking in -been super busy at work so not much fun in bangerland. I'll leave this here: 3E662656-C501-4B22-B8A2-6FF37FA16B06.jpeg
    Old Dawg, rwrj and stubbsrodandcustom like this.
  10. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Should be pretty stout compared to a A motor... Id probably say you will be in the mid 60 to 70 hp area. Slide a cam in that block and really start getting the HP up. My coupe is at 95 with my setup and the motor isn't smooth, its rowdy but it pulls everywhere...
    Personally I think your spot on right where you are at with dependable and drivable fun.
    They do sound good cammed though... Just FYI...
    Super88, Outback, v8flat44 and 9 others like this.
  11. trikejunkie
    trikejunkie
    from Scotland
    That sounds and looks brilliant , subscribed too but couldn`t leave any comment
    stubbsrodandcustom likes this.
  12. A friend sent me this pic of a head to try and ID it. No other pics.
    Anybody got an idea? 2 port Chev?
    Interesting roller rockers. Thanks!
    Jet96 likes this.
  13. Mainedrifter2
    Mainedrifter2
    I now know why my banger won’t start !
    Outback likes this.
  14. 29 Speedster
    29 Speedster
    from Colorado
    Does anyone recommend using a “Fire Wire” between cylinders when installing an OHV Head on a Model A/B Engine?
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    I vote for McDowell... the raided bosses at either end near the intake ports seem familiar. Pics from an original ad posted last month...
    554A95FC-C072-4AC5-80F3-4C834BC261AC.png 999AC4E2-77D7-4092-804D-9552FD94F8E7.png
    Outback, Carter and Jet96 like this.
  16. 29 Speedster
    29 Speedster
    from Colorado
    this is a picture of my McDowell.
  17. Kevin Pharis
    Kevin Pharis
    from Califunny
    She’s a beauty! And clearly shows the top profile of the McDowell head is different than the one posted above. Anyone else...?
    I like your choice of carbs too;)
    29 Speedster likes this.
  18. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I would almost tell him to pull dimensions from mounting stud holes and lay that out on cardboard, real fast and easy way to go through and see what it fits.
    Old Dawg likes this.
  19. 29 Speedster
    29 Speedster
    from Colorado
    As a point of reference, this is a 28 Chevy Head. The. intake port flanges are vertical, and Spark Plugs are installed at an angle.
    G Baese likes this.
  20. rwrj
    rwrj
    from SW Ga
    Been there. You know about the magnet in the flywheel trick?
  21. V4F
    V4F
    from middle ca.
    use modern bendix
  22. Mainedrifter2
    Mainedrifter2
    Hey RWRJ, I do not know the magnet in the flywheel trick ? I can assume … I’ve been working an extension magnet in there and have had some luck with the Bendix spring clips that were lost.
  23. jim1932
    jim1932
    1. Ford A and B speed
    Stupid question probably... I know there is a gasket for between the header and the block on my B. Is there any sort of gasket to go between the burns intake and the header?
    Super88, Dustyp489, v8flat44 and 2 others like this.
  24. BeaverMatt
    BeaverMatt
    Yes, I'd recommend it. I made my own out of gasket making material.
    Carter and Old Dawg like this.
  25. V4F
    V4F
    from middle ca.
    i made my own out of good gasket material , used gasket sealer . been working for years ...................
  26. jim1932
    jim1932
    Fel-pro it is.... Thanks
  27. winduptoy
    winduptoy
    IMG_20220412_103107255.jpg I usually hang onto the gasket when the exhaust burns thru and re use just the intake portion...rests on the studs nicely for assembly
    Old Dawg, rwrj and G Baese like this.
  28. winduptoy
    winduptoy
    Carter, Old Dawg, rwrj and 3 others like this.
  29. denis4x4
    denis4x4
    from Colorado
    I have a boatload of banger stuff including performance parts. Are there any swap meets in northern New Mexico, Colorado Springs, Denver, Grand Junction, etc. in the next couple of months?
    Midnight Rider, Old Dawg and Outback like this.
  30. rwrj
    rwrj
    from SW Ga
    Yeah. Just stick one of those small, powerful magnets behind the ring gear, take the plugs out, and turn it through until stuff stops sticking to it. First time I did mine, I picked up a couple of bolts and about five of those little eared washers. Some of it was probably down there since 1928.
