Hot Rods are 37-8 Pontiacs open driveshaft?
Discussion in 'The Hokey Ass Message Board' started by rusty1, Sep 17, 2018.
  1. rusty1
    rusty1
    this should be easy/quick,...are they open drive?...are any earlier floor shift trans the same in Pontiac, Olds or Buicks?
  2. Hnstray
    Hnstray
    from Quincy, IL
    Yes, open drive.
    I don't fully understand your question about others transmissions...
  3. BJR
    BJR
    Olds is open Buick is torque tube.
  4. 56sedandelivery
    56sedandelivery
    Seems to me, 36-56 Olds/Pont are virtually the same, and open driveshaft. They take a U-joint that bolts together onto the flange, different than 57 onward. I am butch/56sedandelivery.
  5. Hnstray
    Hnstray
    from Quincy, IL
    There are other things that are useful to know about these BOP transmissions .....there are two versions. They are commonly referred to as “5 bolt top cover” and “6 bolt top cover”. While nearly identical in design elements, they differ in physical size and strength. The trans case to bellhousing bolt pattern, at a glance, looks the same but is not. They do not readily interchange.
    The 5 bolt cover models are (lighter duty units) used behind the smaller series engines (Olds and Pontiac 6 cyl/287 V8 and Buick 248/263/264 8 cyl) .....and the 6 bolt cover version (quite strong) used with larger 8 cyl inlines and most V8s.
    Another quirky design element is....these (both 5 & 6 bolt units) do not have a bolt on front bearing retainer/TO bearing support tube. The stock bellhousing for these have a rather small center hole and a TO bearing support tube is slipped into place in bellhousing (there is small flange on tube) and retained in place by the trans when bolted. They also require a gasket between trans case and bell housing because the front bearing is not sealed (except by said gasket).
    Ray
    i.rant, Stooge and 1934coupe like this.
  6. rusty1
    rusty1
    ...a buddy wants to bolt on an open drive trans with floor shift to his 34 Pontiac strate eight engine/bellhousing,...was told a 38 Pontiac floor shift trans would work,...shoulda stated that in my post I guess,..thanks much for the info ...
    looks like he'll have to know his bellhousing bolt pattern before he buys one.
    ...does anyone know if it would be the 5 bolt top cover or the 6bolt?
  7. 1934coupe
    1934coupe
    Good info Ray. Some people have knowledge on certain things or subjects and when you put them all together on a site like Hamb, well it's like an encyclopedia BG (before Google). Keep up the good work fellow Hambers.
    Pat
    zzford likes this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    I am sorry to say, my familiarity with GM transmissions doesn’t reach as far back as pre 1937 era. :(
    Ray
  9. BJR
    BJR
    Like the OP said "shoulda stated that in my post I guess". This happens way too many times. The OP will ask a question and gets many responses...... Then he ads a detail or two, and we find we all went in the wrong direction with our answers, due to a few important details missing in the original post.
  10. rusty1
    rusty1
    ^^^maybe so, but some good info here none-the-less...
    Hnstray likes this.
  11. fro5555
    fro5555
    from No IL.
    Hi I'm the guy that has the 34 Pontiac, & I would like to replace the trans to make it an open drive shaft. and keep the same clutch. I have it out & it has 4 bolts in the top plate. The number on the trans is GM 590695. I looked in the repair manual and it has 4 bolts in the picture. This is in a original car with a straight eight. It has a bellhousing hole fit of 4 3/16", input shaft is 10 spline & is 6 11/16" long. the bolt hole center across the top is 7 1/2" , down hole to hole center is 4 1/2". Thanks for any info.
