its the corvette chervrolet slip yoke c4 aluminium version that uses outy clips, because its aluminium and 1310 so they are a stock item ahh - when you search c4 corvette slip yoke you get ford c4 automatic ones pop up bugger
ok how long is a stock s10 slip yoke thanks 6.125 inch long ? 27 splines - ? gm - for gm s10 t5 1310 - ? 8'' ford yoke is 1310 - yes outy clips on stock s10 slip yoke - no ideally want 1310 each end each end
CHEVROLET ASTRO 1989-1998 CHEVROLET BLAZER 1995-1996 CHEVROLET K1500 PICKUP 1989-1991 CHEVROLET K2500 PICKUP 1989-1991 CHEVROLET K2500 SUBURBAN 1994-1995 CHEVROLET K3500 PICKUP 1989-2000 CHEVROLET S10 BLAZER 1989-1993 CHEVROLET S10 PICKUP 1989-1995 CHEVROLET V1500 SUBURBAN 1989-1991 CHEVROLET V2500 SUBURBAN 1989-1991 CHEVROLET V3500 PICKUP 1989-1991 GMC JIMMY 1993-1997 GMC K1500 PICKUP 1989-1991 GMC K2500 PICKUP 1989-1991 GMC K3500 1989-2000 GMC S15 JIMMY 1989-1990 GMC S15 PICKUP 1989-1990 GMC SAFARI 1989-1998 GMC SONOMA 1991-1995 GMC V1500 SUBURBAN 1988-1991 GMC V2500 SUBURBAN 1988-1991 GMC V3500 PICKUP 1988-1991 OLDSMOBILE BRAVADA 1994-1996 does that mean you can get a t5 tremec in any of the above? then you ask yourself its JUST a two wire hall efect sensor -so is it simply a crank position sensor from something or an abs wheel sensor from something could there be a sensor from something else that is exactly the same - crank position sensor, that has a moulded in tail and a couple of feet of wire
