Hot Rods Are stainless Mufflers worth the cost ?
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Jan 14, 2017.
  1. blazedogs
    blazedogs
    Due to the change in seasons and simply not driving our old cars as much as our family car the mufflers fill with water , condensation and rust out in a short time. They never get hot and dry out.On my 49 Ford I,m replacing muffers about every 3 years. I'm getting ready to buy mufflers for a new project . The prices of stainless is very high compared to steel. The stainless advertized are( not all stainless anyway), only the outside shells are stainless in many cases or just a few of the inside components.
    My question: Is buying stainless worth the high cost and is their a good muffler on the market that you have been happy with from your own experience.? I should add- I like loud and throaty...
    Gene
  2. hinklejd
    hinklejd
    from Fort Worth
    Mild steel mufflers on my DD did the same - rot out and fall apart every 3 years or so. I put in a stainless Magnaflow probably 8 years ago and haven't had to touch it since. So, yes, the increased cost provides increased value. The MF mufflers are basically gl***packs with fibergl*** allowed to move about and turn exhaust noise into heat. Relatively quiet-ish at idle, but straight through design acts like a straight pipe at higher RPM. As always, your mileage and experience may vary.
  3. A Boner
    A Boner
    Look up "mufflers never-rust exhaust systems" on he web......about $90/muffler. They are 100% non-magnetic stainless steel. Had mine for over 20 years! Sound good too.
    They are in Pittsburgh, Pa.
  4. teejay99
    teejay99
    Stainless exhaust came with my 01 Olds Aurura and the mufflers lasted 13 years .....rest of the original exhaust is on the car ( now 16 years ) so ....yes they are worth it IMO .
  5. mitch 36
    mitch 36
    I put stainless baffled mufflers on my sedan . Got them from " Stainless Specialties "about 20 yers ago and they are still like new, my car doesnt get driven as much as it should either. They are 304, thats the key as the stainless most mufflers are made from is not as corrosion resistant as the ones made of 304. Mitch.
  6. chevyfordman
    chevyfordman
    X 2 on stainless
  7. miker98038
    miker98038
    My new set of Stainless specialties is 10 years old, the old ones probably over 20. Pricey, but cheap in the long run
  8. Hot Rod Cowboy
    Hot Rod Cowboy
    30TudorSedan likes this.
  9. X3 or 4 on Stainless Specialties mufflers. Have them on my DD big block El Camino for 15 or so years. This car is reversed in on an incline and they are still holding up. Sound great too.
  10. toml24
    toml24
    I always thought a pair of circa 1970 Thrush Side Pipes would look very cool on the side of any car. To me they make a big time ultimate power statement. The outside is polished aluminum, which will corrode but not rust. The looks of those Thrush Side Pipes really hold up after 47 years.
  11. BamaMav
    BamaMav
    from Berry, AL
    Still have the OEM muffs on my 99 F150 and 00 Expy. Not sure what they are made of, but they sure have lasted.....
  12. denis4x4
    denis4x4
    from Colorado
    Exhaust system on my Zipper is stainless and and 18 years old with zero issues.
  13. I put stainless Holley gr*** packs on my ride 18 years ago, they sound the same today as they did when I put them on. IIRC they were a 100 bucks back then and I would do it again in a minute.
  14. rush549
    rush549
    from Kansas
    Drill holes in it. lots-o-holes. Holes in the bottom to drain. holes in the top to vent. Then take them off, throw them in the lake. They make nice fish sanctuaries
  15. I haven't bought a muffler in about 50 years, maybe 60, so I don't know what they look like now. But way back, mufflers had one weep hole at the down low, so moisture dripped out. I ***ume the hole was large enuf to drop water but not enuf to affect the g***es.
  16. gene-koning
    gene-koning
    They have not put the weep holes in mufflers for at least the last 20 years. How could they sell you more if they didn't rot out?
    I've got plain old mufflers on my stuff. I drive the vehicles long enough to completely dry out the exhaust at least once a week during the driving season. My 4x4 has the most recent muffler install, and its about 5 years old now. The muffler looks great, I'm not so sure about the pipes at this point. Gene
  17. vintagehotrods
    vintagehotrods
    Buy stainless steel, you won't regret it.
    Here's the deal of the year at Summit. Thrush Polished Stainless Steel Gl***pack Mufflers 24239 on clearance for only $29.50 each. Regular price is $99.97. I bought a pair just to have them on the shelf but the only size at this price is the 2 1/4" which is just fine for most applications.
    https://www.summitracing.com/parts/wlk-24239/overview/
    Nostrebor likes this.
  18. vintagehotrods
    vintagehotrods
    An afterthought about my experience with a Magnaflow Stainless Steel muffler with a lifetime guarantee on my tow vehicle, a 1999 Chevy short box crew cab big block I've had for 17 years that's pulled its guts out for 158,000 miles for me. I blew the guts out of the first one and they replaced it and the tailpipe for free and its been fine ever since. Nothing kills mufflers like towing a heavy load. In fact, I just sold my old girl yesterday. It still has the original untouched engine and trans. It was the best truck I've ever owned.
  19. TagMan
    TagMan
    I bought my '37 Chevy coupe in 1993 and the PO had installed a stainless steel muffler on it several years previously. I drive the car about 2-3k miles a year and the muffler sounds & looks as good as it did when I bought it 24-years ago.
  20. belair
    belair
  21. Bugguts
    Bugguts
    Gee, if nothing ever rusted out, wore out or broke, I'd never get to play with my old rides!
  22. 383deuce
    383deuce
    a ***** is right I have had them on my sedan for over 25 years and no problems
  23. blazedogs
    blazedogs
    One of you made a interesting point. Years ago when installing a new muffler we alway drilled a 1/8 inch hole in the lowest point on the muffler for water to run out. A few local muffler shops still do that for customers. So why isn't everyone doing this? It seems like this makes a lot of sense ! Gene
  24. For the same reason stainless steel headers and pipes make sense.
  25. dan c
    dan c
    stainless good, but i've never had aluminized pipes rust out--one of the benefits of unleaded gas. don't think there are many more...
  26. mgtstumpy
    mgtstumpy
    I bought similar S/S gl*** packs to above (#18) and had the entire system done in S/S for longevity etc. Plus I had the cast headers coated for similar reasons.
