Are Steering '37-'48 parts Matched...??
Discussion in 'The Hokey Ass Message Board' started by Enbloc, Oct 19, 2009.
  1. Enbloc
    Enbloc
    from London, UK
    With 37-48 used steering components, does the worm and sector have to be kept together as a matched pair due to wear patterns?
    Can you add a new worm to a used sector and vice versa?
    Is it possible to remove the worm from the steering shaft without damaging it so it can be used again?
    Thanks
  2. thunderbirdesq
    thunderbirdesq
    I've rebuilt several boxes that needed only the sector or the worm replaced with no ill effects. The worm can be pressed off and reused if need be.
