Hot Rods Are the old tried & true rear axles getting hard to find?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Dec 6, 2020.
  1. nobby
    nobby
    does anyone have the bendix part number of a 1966 bronco back plate?
    11 by 1 3/4'' brakes
    IF you can fit a 66 bronco rear drum onto a 56 ford f100 rear end dana44
    same pcd, same hub register same diamter and shoe width
    PLUS same big bearing 3.150
    plus no one knows the dimensions of the bolts spacing on an early ford big bearing end
    what are the chances of the back plates being the same
    moreover, what are the chances of the bearing housings being the asme thing? even though the dana44 has pressed in knurled studs rather than t bolts
    note to self..
    32 heavy axle is 50.5'' king pin to king pin
    40 ford axle is 48.5
    32 heavy + 40 spindle + 56 f100 brakes = 59 1/8
    40 ford axle and spindle f100 hub would be 57 1/8
    s**** the 32 heavy and go stock!! or narrow the 32 heavy 1/2'' per side and drop it a tiny tiny amount = 58 1/8
    5.5j is 6.5 edge to edge 4'' b/s (actual et positive 38mm 1.5'' = 56 1/8'' track
    or 5.5j et38 =56 1/8
    outside wheel edge each way plus 5 = 61 1/8 rim outer to rim outer - double check
    bronco rear 58 1/8''
    stock 40 axle with f1 hubs would get you 58 1/8
    don't forget camber lean
    HOTRODPRIMER likes this.
  2. 1934coupe
    1934coupe
    I only have Olds/Pont rears and I'm getting rid of them all for one low price of $1500.00. It's time for me to clean out so my family won't have to. So anybody looking, look no further.
    Pat
  3. trollst
    trollst
    I read this whole thread, I've always been amazed by the guys who figure a nine inch is the only way to go, as it will take the horsepower. I've had discussions with customers over the same thing and its all brain washing.
    I have always run the cheapest narrow housing I can find, not picky who makes it, my 36 ran a gm ten bolt for 18 years, till I put a ford 8.8 ranger rear in it, behind a 330 horse 327, lots of abuse, never a whimper. Why? Simple, the truck weighs 2770 lbs, will light the tires on fire at will, long before anything will break. It's not a 59 caddy, doesn't need huge strength, 31 spline axles are a waste of money, unless I want to pay for bragging rights. I don't.
    I upgraded because I wanted to change wheels, the ten bolt was just that little bit too wide, I found an 8.8 with 355 gears and a trac loc with very low miles for $400 complete, changed the spring mounts and in it went, changed the oil and went drag racing.
    Traditional may be cool, but can get expensive, nobody has ever looked under mary and commented on the parts I used to build her, and I've never hurt a rear end yet.
    partsdawg, 210superair, X-cpe and 5 others like this.
  4. lake_harley
    lake_harley
    ^^^^True. When I narrowed 1 side of the 8" housing I did, I bought a "cut-to-fit" Yukon brand axle. With bearing it was $170-ish if memory serves.
    I have since looked into having axles re-splined for an 8 3/4" Mopar axle for something else. The one local machine shop I checked with didn't have the correct equipment to re-spline axles so I checked several companies like Moser, Dutchman, etc.. I don't recall an exact price for having them re-splined, but with the expense of shipping axles both ways to have them done I think $170 for the cut-to-fit axle with bearing was a decent price.
    Lynn
  5. hotroddon
    hotroddon
    The last nine inch was used in 1986! That's 34 years ago and that was in the F-150, the last US p***enger car with one was the 1980 Granada. The last 8" was used in 1980 as well - so 40 years ago!
    AHotRod and H380 like this.
  6. Hitchhiker
    Hitchhiker
    I should add, that I think this is why it APPEARS that they are getting hard to find. Truth be told I've never had trouble finding old rear-ends when I need em. Sometimes they're cheap too!
  7. BamaMav
    BamaMav
    from Berry, AL
    I was thinking it was 96 in the F150, but you may be right. Still a long time ago either way.
    My sense of time gets worse every day. Things I think happened a year or two ago actually happened 10 years ago or longer. I guess that’s why I have CRS, can’t remember ****......
    williebill likes this.
  8. Beanscoot
    Beanscoot
    How many do you get for that one low price?
  9. theHIGHLANDER
    theHIGHLANDER
    Here's more info about narrowing, say it's close and you only need an inch or so off 1 side, maybe less or a wee bit more on the other. Got a chop saw or a buddy with one? Look at the splines. Many have 2 1/2 or more of spline that never gets used (like a guy with a big...:eek: oops never mind) so you can trim that off as long as the original wear mark is equal plus a bit onto what's left. Make sense? So if the wear is about 1" and you have 2 1/2" to play with and you lopped off that inch you're at 1 1/2" of spline and still good to go. Lop it off, grind in a bit of taper, wire brush it and run it. And yeas, ROUND TUBE axles. Oh, this just in from the FWIW dept, adding Ford brakes to any axle works with the right housing end (big Ford Torino is the norm) regardless of make. It also eliminates the 'c' clips on the GMs and such. I know, too easy right?
    thintin, Tman and Rickybop like this.
  10. Rickybop
    Rickybop
    Using different axle ends to fit different brakes.
    That's a gold nugget.
  11. theHIGHLANDER
    theHIGHLANDER
    The right bearings and retainers are needed too, just figured that was nearly obvious.
  12. 31Apickup
    31Apickup
    The last one I did was a f150 rear, you could get them for $100 at a local yard in Michigan (15 years ago), 31 spline. I cut and rewelded and bought cut to fit axles which were reasonably priced. I was recently in a pick and pull yard several weeks ago here in Seattle area and there were several pre 87 pickups and vans. There is also a falcon 8” on Craigslist last week, one complete rear and one housing for $150.
  13. goldmountain
    goldmountain
    I picked up a very narrow 9" housing and axles at the swap meet. Perfect for my little Austin Ruby. Also bought a center section with the 4.56 gears that I want. Had no problem trading the spool for a open case. Sort of overkill for my 1000 cc. engine but it was cheap enough.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  14. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Just because you have never broken a rear axle or a rear end doesn't mean everyone else can't/won't. Something you also aren't considering is that with the 10 bolt rear ends they use C-clips to retain the axles. If you break an axle, you can lose a wheel and bad things can happen. Having the foresight to overbuild when someone has decent hp and traction is a good thing. The point is that many cars have hp levels that may never tax a 9" rears abilities, BUT you never know how a less strong rear may hold up. It depends on how the builder plans to drive the car. If someone starts out to build a "hot rod", one would think that the rear end is going to get tested ........
    dirty old man and trollst like this.
  15. nobby
    nobby
  16. Beanscoot
    Beanscoot
  17. trollst
    trollst
    I don't worry about c clips, there are literally millions out on the road, failure rates are? Who knows, I never see it. Not that your post doesn't have merit, it does, and if I were going to race or put ridiculous power in a car, I'd match the ****** and rear end as well. Just saying, for most guys, not an issue, last year I upgraded an 8" to a 9" in a model a coupe, cause the owner wanted a 409 for the car, I wouldn't have upgraded if it were mine, but he got what he paid for.
    theHIGHLANDER and ekimneirbo like this.
  18. Yep, I've done that; works well. I narrowed a small-bearing 9" housing and needed shorter 28 spline axles. Looked in my stash, I had some 8" axles with the same bearing and the right splines and close to the right length, trimmed off about 3/4" on each one and had my no-cost narrowed axles...
    theHIGHLANDER likes this.
  19. nobby
    nobby
  20. nobby
    nobby
    aahh the ford ranger parts car
    rwd 2.3 duratec mazda L
    exhaust p***enger side , throttle body to front
    rwd block to ch***is motor mount legs
    rwd oil pan to clear front crossmember
    getrag 6 speed manual, with cable shift - remote cable shift move forwards where you want it.
    stock reworked driveshaft
    dana44 re axle and braked for 5.5'' pcd
    tanks poly tank modified to receive stock fuel pump, glue in swirl pot click fit, screw top , with the click on charcoal filter
    use the plastic fuel lines and clips
    keep the smog return line and valve.
    je;lly bean 2'' stainless exhaust to go through a 35-40 frame
    keep the pats and the fuel pump controller.
    aftermaqrket fuse box for permanent live and switched live, that has the color coding on it to ***ist in loom mod
    electronic dials sans digital read out, pre programmed to getrag with ranger gear ratio and 235 75 15 tyre
    I wonder if they are electric or hydraulic steering
  21. big john d
    big john d
    from ma
    cut the axles out of the center of the housing at the weld clean up the ends and grind a slight taper on the tubes then press them back in to the desired length check straightness and reweld the tubes into the center section be sure to index the axle retainer flange to keep the bleeder at the top no real reason to buy billit ends when the original lasted for 40 years also the tube can be left long enough to be pressed in far enough to weld a support gussset inside the housing
    X-cpe and seb fontana like this.
  22. nobby
    nobby
    i was thinking drill through the plug welds, press the whole tube in, and plasma cut it on the inside, tickle it up with a burr - especially If you were going from 61 inches wide to say 57, press in 2 inches per side, cut off 2'' inside
    would be really funny if there were a leaf sprung axle out there - rear loader, where you could press the tubes in and the spring pads landed exactly at 35-40 ford ch***is engineering leaf spring kit..........
    anyways, that leads to - is the casing cast iron and then if the tubes are steel, what rod do you use to weld them - been done already ....
    anyways, if you then bought the dutchman extra long splined shafts, and realised you needed another (for example) 1/2 inch per side, at least you could ***emble the thing and not weld the plugs back to see if it were correct.
    or at least it gives you the option in the future to see a bit more ankle in the future
  23. 31Apickup
    31Apickup
    I do know where a 57 Ford wagon 9 inch is sitting in a state park in Michigan. Car is sitting on its roof mostly rotted away. Someone did pull the rear end, but never went back for it. I haven’t been back in there in a few years to see if it’s still there.
  24. typo41
    typo41
    Here are the listings this mornings CL Inland Empire CA
    1962 Ford Galaxy rear end - $350 (29 Palms)
    '68 Ford Fairlane rear end - $700 (29 Palms)
    Ford 9" rear end 9 inch drop out differential axle ***embly - $500 (San Diego)
    Ford 9 inch center 4.30 gears Detroit Locker - $1,250
    Ford 9 inch 3rd member 350 Gear - $800
    9 inch Ford rearend Lincoln versailles - $1,200 (fontana
  25. Jeeze, I should start buying **** up and taking it West.
    partsdawg, 2OLD2FAST and Budget36 like this.
  26. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is a video about doing that And also a pictorial article: http://mmb.maverick.to/threads/explorer-8-8-rear-end-bracket-welding-install-pictures.77673/
    51504bat likes this.
  27. nobby
    nobby
  28. topher5150
    topher5150
    They're pretty plentiful here. Found about a dozen rangers and six or seven explorers and mountaineers in one junkyard.
    Sent from my moto z4 using The H.A.M.B. mobile app
  29. partsdawg
    partsdawg
    from Minnesota
    I used to get axles re-splined at semi tractor repair shops
  30. goldmountain
    goldmountain
    While trying to figure out where to get front suspension pieces small enough for my Austin project, I was nosing around on Alibaba and noticed that my cousins over in China are selling new 9" axle housings. This will probably get negative responses, but thought I would let you know.
