are there 4 bolt wheels bigger than 13"
Discussion in 'The Hokey Ass Message Board' started by wreckfixer, Sep 10, 2009.
  1. wreckfixer
    wreckfixer
    we got back on the kids 64 Falcon, and i think it needs some bigger wheels than the original 13's I don't recall if any OEM wheels were bigger. Can someone help?
  2. hotrodlarry
    hotrodlarry
    Not sure what the bolt patter is on the Falcon right off my head, but check the 70's/early 80's Mustangs. They are 4 lug. So are the midsized LTD's/ Marquis wheels.
  3. plodge55aqua
    plodge55aqua
    from Alberta
    If Im not mistaken 6cyl cars had 4 bolt lugs.. 8 Cyl cars had 5 bolt lugs.. I could be wrong though..
  4. brandon
    brandon
    aren't they the same as the later mustangs and other fox bodies...?
  5. R Pope
    R Pope
    My '79 'Tang had 14" 4-bolt wheels.
  6. 55 dude
    55 dude
    my 67' mustang has 14' factory wheels
  7. H3O
    H3O
    they made 14" for them. bolt pattern is 4 1/2". just 4 lug. might even find 15 but i know for sure they made 14". they're like 14x5.5 or 14x6.
  8. bbc 1957 gasser
    bbc 1957 gasser
    my 88 has 4 lug 4 1/2 bolt pattern and they have 15 inch alum. wheels or 14 steel ..or 17 and up in after market
  9. Kinky6
    Kinky6
    '64 - '66 Mustangs had 4 bolt 14" wheels, Falcons from the same time period probably are the same.
    2 ideas: check with some Mustang restoration shops in your part of the state, see if anyone is converting a T code six to a V8 and changing out the suspension, and also check out Fordsix.com, maybe someone there will have a lead on some 14's near you.
    Good Luck, *****6 :cool:
  10. cruzingratiot
    cruzingratiot
    from Detroit MI
    Quoting the Hollander book.
    4x4 1/2"- lug
    13 x 4" & 4 1/2"
    13 x 4" Falcon exc. S.W. & H. D.
    13 x 4 1/2 " Others
    Comet '60-64 6 cyl
    Comet '71 13" wheel
    Falcon '60-65 6 cyl
    Falcon '66 6 cyl. 2 & 4 dr Sdn.
    Maverick '70-71 13" wheel
    Mustang '65-66 6 cyl. std equip 13"
    14 x 4 1/2"
    C4DZ1007A exc. Comet & Maverick
    D0DZ1007E Comet & Maverick
    Comet '65 6 cyl
    Comet '71-72 14x4 1/2, 4 stud
    Falcon '64-65 6 cyl
    Falcon '66-67 6 cyl 2 & 4 dr Sdn
    Maverick '70 14x4 1/2
    Maverick '71-72 14x4 1/2, 4 stud
    Mustang '65-66 6 cyl. optional 14"
    Mustang '67 6 cyl.
    14 x 5"
    Chevy II '62-63
    Covair '62-64 disc. exc. fwd. cont
    Falcon '67 6 cyl exc. S.W.
    Falcon '68-70 6 cyl exc. S.W.
    Maverick '70 14x5
    Mustang '68-70 6 cyl
    14 x 6"
    D0DZ1007C
    Comet '72 14x6 4 stud
    Maverick '70 14x6
    Maverick '71-72 14x6 4 stud
    15 x 4" & 15 x 4 1/2"
    Jeep 939999
    Jeep DJ Dispatcher w/ 4 stud wheel
    IH 860221R91
    Intern'l Scout 80 & 800 4x2
    3150286 Rambler '50-57
    Willys '52-55 P***
    Paul Jug
  11. Judd
    Judd
    Yes I sold a 65 Comet parts car that had 4 lug 14" wheels.
  12. jmthehermit
    jmthehermit
    from Bath, Pa.
    Ford also made 14" wheels with a 4.25 bolt pattern used on some T-Birds and Granadas. Metric 108 mm.
  13. wicked creations
    wicked creations
    from oklahoma
    try ford probe gt wheels i have some on my model t with a pinto rearend. They had 15 inch 4 bolts that were a 3 spoke that you can polish
  14. In my experience the later Ford 4-bolt is different from the early Ford 4-bolt pattern (4.00" versus 4.25", I believe). Some of the Falcon line was available with 14" x 4.25" as said already.
  15. just be carefull some of those early 80's 3 spoke aluminum where a metric rim, that require a metric tire. I believe that michilen was the only company that had or has a metric tire to fit that rim still
  16. todd_a
    todd_a
    from Tyler, TX
    I've bolted on wheels from a 1984 stang on a 1965 before. Fit fine. The 1965 would not work on the 1984 though because of disc brake clearance.
    Also, you can get any 4 lug up to 1993 from the stangs and it is the same bolt pattern. They made these up to 16" and you can get aftermarket wheels in that bolt pattern up to 20" if I remember right.
  17. 4x4.5" Mustang went up to 1993, the last year of the Fox platform. All 4, 6, and 8cyl had the same 4-lug pattern.
    Some imports have a 4x114.3mm, which is the same as the 4x4.5". Like Mazda RX-7 Base models and other rear wheel drive cars.
  18. wreckfixer
    wreckfixer
    That's alot of good info,thanks.
  19. falconwagon62
    falconwagon62
    yes V8's were ALL 5 lug, 4 Lug were 6 BOTH were 13" I have 2 sets of 13" 5 lug, same on a 63 Fairlane.
    Mustangs Had 14" 4 lug and 5 lug wheels, they bolt right on, if its a 4 Lug, GOTTA be the older BC, the newer BC WILL NOT FIT...
    5 lugs, yea, Bolt on new Mustang Bullitt wheels, you'll need to space it out an inch, but the 5 x 4-1/2" BC is the same...
  20. metalshapes
    metalshapes
    Fox body wheels wont fit a Falcon.
    I believe MGB does fit ( 4 bolt, 4.5 pattern ), and some late model Japanese cars.
    The Tuner guys might not be looking for 4 spoke daisy mags yet...
  21. hotroddon
    hotroddon
    The original Datsun Z Car's had 14" in the same bolt pattern. Ran them on the wifes 61 Comet Wagon
  22. sk8ncruz
    sk8ncruz
    from pratt, ks
    got a set of like new 14" 4 bolt aluminum wheels with tires I would love to sell had them for my 66 mustang and never used them, was going to but them on my falcon project, but trying to sell the project now.
  23. Bassfire
    Bassfire
    from Mart, Tx.
    I had a 62 Buick Skylark that had 15" 4 lug wheels but don't know if they have the bolt pattern you are looking for.
  24. http://www.vehicle-bolt-pattern.com/ford-lug-reference-guide.html
    79-93 Mustangs have a 108 mm bolt pattern, which is ~4.25".
    Falcons have 4.5" which is 114.3 mm.
  25. Harry Bergeron
    Harry Bergeron
    from SoCal
    Fox body offered 16 in. 4-bolt 5-spoke "Pony" aluminum wheels for 1993,
    fairly attractive.
    85-93 Fox bodies had different 15 inch aluminum wheels, "10-hole" and the very ugly "turbine" style.
    84-up 4-cylinder mustangs had steel wheels, 14 inch I'm guessing.
  26. Spity
    Spity
    I was winterizing the car and pulled the front wheels off, and took a snap half way through they are now sitting in my garage 4 sale. I bought these last year they are "Ansen Sprint" knock offs made by american racing.
    American racing makes several wheels that fit the 4 lug pattern your after. Mine are 15x7 with 4 inch back space.
    They also make the ugly outlaws, and outlaw IIs in 4x114.3 You can also type in your bolt pattern in summits website and they give you a bunch of options.
    You can also buy Adapters that bolt on and change your bolt pattern to 5 lug, and then just order your wheels with the extra backspace of the adapter. I talked to a guy who sold Cloys wheels and he said alot of guys are doing it who are cursed with 4 lug and want something different.
  27. GTS225
    GTS225
    Here ya go......scroll down about halfway and you get a chart with pics. All of the rims listed are for cars with 4x4.5" pattern. I found it when looking for rims for an O/T car.
    http://kmhafer.datsun510.com/wheelFAQ.htm
    Roger
  28. hugh m
    hugh m
    from ct.
    Some of the early Nash Ramblers had 4 lug 15" wheels that would fit a Falcon, used them on my 283 powered Falcon, were easy to find in the sixties, and worked well.
  29. farna
    farna
    1950-55 Nash Ramblers used the four lug 15" wheels, but they are NARROW!! 4"-4.5" at the most. Were made for a 6.40x15 tire. The Nash service manuals don't give any wheel specs, just tire size.
    All the 56-57 Ramblers (larger, 108" wheelbase -- the 50-55 Nash Rambler had 100" WB except for the 55 four door) I've seen had five lugs, that isn't mentioned in the service manuals either, and my parts books only go back to 1960.
  30. Little Wing
    Little Wing
    from Northeast
    Chevy nova and early Volvo fits Ford
