Are there any downfalls to using a 336 8ba
Discussion in 'The Hokey Ass Message Board' started by Frankenshovel, Jul 20, 2007.
  1. Frankenshovel
    Frankenshovel
    I'm ***uming it's a 49-53. Bellhousing is not a part of the block and water outlets are at the front of the heads. This morning I tried to put a 50' ford 8ba bellhousing on this-what I'm ***uming is a 336, it didn't go on so easy. BTW, I did that so I could run the 3 speed overdrive. I'm just wondering if I'm spinning my wheels? All input is grately appreciated.
  2. the-rodster
    the-rodster
    I think that you are referring to the 337 Lincoln/Truck flathead.
    They are ginormous beasts, and I was under the impression that none of the regular flathead parts interchanged.
    Do a search on here for "Lincoln flathead"
    Hope this helps.
    Rich
  3. 302GMC
    302GMC
    from Idaho
    Depends on what you put it into ...
  4. Flatman
    Flatman
    Speed parts are like hen's teeth to find for the 337cid flattie.
    Flatman
  5. xlr8
    xlr8
    from Idaho
    not to mention that it weighs like 800 lbs.
  6. Little Wing
    Little Wing
    from Northeast
    This is a 337 bell,,and a 337 3x2 intake
    They are 337 and there is teh Lincoln motor and the Truck,,"L" casting is Lincoln "Q" is the truck motor,,and came in solid and Hyd. lifters,,and yeah bout 850 lbs,,lol
