Projects Are there any lancer style caps in a 16"?
Discussion in 'Traditional Hot Rods' started by bedfordboys, Jan 9, 2014.
  1. bedfordboys
    bedfordboys
    from bedford va
    I've got a 41 chevy, 6 on 5 1/2 bolt pattern. I knew rims were going to be hard to find if you could find any at all (I can't). But all the 16" caps I can find are smoothie's?
  2. Dreddybear
    Dreddybear
    I have never seen any. There are moon caps, smoothies (try hub cap mike), sombrero style (sorta rare), Cadillac limo caps (ultra rare) and some other small run type stuff.
  3. falcongeorge
    falcongeorge
    from BC
    Lyons made a few different 16" hubcaps that could work for you, Do a search, maybe you will see something that will work for you, but anything you find in 16" is going to be more appropriate for a forties/early fities style custom, not late fifties/early sixties.
  4. oldolds
    oldolds
    Rims hard to find? All 1/2ton 2 and 4 wd Chevy trucks untill 1970. 4wd till much later. Will get you 15" rimd and some 16"s. Nissan trucks also had 6 lugs. Can't help you with wheel covers.
