Technical Are there narrow pedal pads out there for early ford pedals.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Nov 25, 2022.
  1. rusty rocket
    rusty rocket
    Running into space problems with my pedals in my new 26 roadster project. Round pedal pads, steering column and transmission hump screw me for room for my gas pedal. I remember so-cal had round aluminum pads that a guy could cut down but I don’t see them on the site anymore. Any ideas out there?
  2. Tim
    Tim
    from KCMO
    I think Snyder’s sells the eclipse shaped pads that would have been on like a T and maybe stick A if memory serves. Instead of laying them horizontal turn them vertical?
    rattlecanrods likes this.
  3. RICH B
    RICH B
    Shoebox pads (like Ansen used) are narrower and while they don't screw on, they bolt on with a stud
    deuceman32 likes this.
  4. chop&drop
    chop&drop
    You might check Mooneyes and Lokar too.
  5. why not get appropriate sized washers, weld studs to them then bolt on? Cut and glue rubber to fit. Not everything has to be 1-800....
  6. da34guy
    da34guy
    Check Gennie Shifter out, I just got 2 that are 2 " wide by 4" tall. Worked real good for me in my 32
    Hamtown Al likes this.
  7. "D" can be turned down. I have always liked this style from Socal
    Pedal Pads (est1946.com)
    alchemy and hrm2k like this.
  8. Blake 27
    Blake 27
    Or "D" could be trimmed on two edges.
    Tman likes this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I use pads from foot actuated emergency brake pedals in some of my builds.
    ffr1222k, High test 63, Tim and 2 others like this.
  10. denis4x4
    denis4x4
    from Colorado
    1C53FACB-6CAC-4FB8-AD33-A3133F52D414.jpeg 909EEC4C-6841-4475-A8EE-64616D9EC881.jpeg
    These are SoCal pads. There also step pads for Model A rumble seats
    Just Gary likes this.
  11. Blake 27
    Blake 27
    Possibly move steering shaft to the left by shortening your sector, then swapping clutch petal
    with a 40-48 style ***embly. This would move everything to the left giving more room for your petals.
    Suggestion from a couch potato who's hardly touched a tool in the last two years. LOL!
    57EFE61C-E0A7-47FE-B248-166A27094AF8.jpeg 0B584213-56E0-428E-B130-8D167ADE0FF7.jpeg Flathead_Clutchassy_1940-48_85hp.jpg
  12. Marty Strode
    Marty Strode
    On the subject of pedals, I didn't care for the look of the Ansen pads, and the offset wasn't correct for my application. So, I bought some pads that were used on Fords in the 50's to the 70's. Made the plates with the offset I wanted, and they worked out great. IMG_9404.JPG IMG_9399.JPG IMG_9407.JPG
  13. krgdowdall
    krgdowdall
    from Alberta
    I used pads from a F1 PU. they were a bit smaller (approx1/4") than the 36 pads I had.
    Not much but it helped. They were reproductions so may not have been to OEM dimensions.
  14. krylon32
    krylon32
    from Nebraska
    Several years ago I found some really narrow aluminum pedal pads at Offenhauser. Dealing with them today is a pain in the ***. For the 32 pickup I built a few years ago I used some narrow pads from Lokar. They were in their Lakester series.
  15. The37Kid
    The37Kid
    Hole saws come in all sizes, s**** aluminum is everywhere.
    Bob
  16. Fordors
    Fordors
    Here’s a photo of the clutch linkage and pedals in my coupe. Can’t see the pedals very well but the pedal pads are early VW.
    435B6C7A-125F-4865-AA65-999DEC1D0F04.jpeg B64C720B-880A-4E6A-BCA3-CDF458DE5F71.jpeg
    jimmy six and Budget36 like this.
    Here are a pair of MC pedals I have on my auto-trans, '50 Chevy.......
  18. Mr48chev
  19. Find some Model A pedals, cut the ends off, weld on the right bolt and get some pedal pads.
    Tim likes this.
  20. rusty rocket
    rusty rocket
    They don’t make D
  21. rusty rocket
    rusty rocket
    Sorry Blake, all that ****s been fabricated not stepping backwards at this point.
  22. rusty rocket
    rusty rocket
    I thought about A pedals running up and down. Maybe even some T pedals.
    Tim and 1oldtimer like this.
  23. nochop
    nochop
    from norcal
  24. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Found these images on the HAMB. I think they are 1960s MGB.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've not been able to find a glue that will take that kind of abuse .
  26. caprockfabshop
    caprockfabshop
    https://www.summitracing.com/parts/...36Z0BhoK2FtukSRQCdHBUrAprbQ8qAHhoCIogQAvD_BwE
    That stuff sets and adheres to rubber like nothing else I've tried. I used it for several applications where the rubber is getting rubbed on and abused and it's never lifted. I'm sure with the right surface prep of the pedal and the rubber it would be fine on brake pedals.
    ~Peter
  27. Sorry to hear it. I used windshield gorrilla snot to hold mine. Used a holesaw to cut the rubber slightly larger than the washer, heated the washer then press fit the two together. Ended up with a full lip surrounding the washer. A bit of the snot, and bob's your uncle. It's not really rocket surgery is it? Jesus wept, it's a couple of pedal pads for cryin' out loud.
  28. I think that might be your easiest way out if that will give you enough room. Easier to find some A or T pedals then to source out some odd makes (cheaper too), plus maybe quicker then waiting for some online places. Fun part will be to make them indexable or land in the right spot and making them lock down so it won't twist when slamming through the gears.
  29. deucemac
    deucemac
    I bought a pair of AC Cobra repop clutch and brake pedal pads recently to help me gain room in my roadster. They are aluminum, very narrow oval, and have a stylized AC engraved on them. I haven't gotten around to it wet, but it looks like an easy bolt on adaptation.
    ffr1222k likes this.
  30. miker98038
    miker98038
    I’m using Model A pads set vertical, and a throttle s****. My 32 is channeled, and the Yblock uses a truck bellhousing and a TKO 500, so the footwells are very narrow. I wear a size 10 1/2 shoe, and I can’t drive it with bulky shoes on. But it works for me.
