Are these the right caddy hubcaps
Discussion in 'The Hokey Ass Message Board' started by 220, Aug 24, 2012.
  1. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Yep, those are the sought after 57 Eldo's and $400 is about what they go for
  2. Ester Eddie
    Ester Eddie
    from Alaska
    Guess so.....or maybe not.
  3. BrandonB
    BrandonB
    from nor cal
    Don't bother. Those things are useless unless you're restoring a 56 Caddy.
    A set of these is what you want.
  4. Atwater Mike
    Atwater Mike
    How do you suppose these Cad hub caps got 'separated' from the cars they belonged to?
  5. The set I got, one was in one barrel here, the other was in a barrel 50 yards away, the guy kept all kinds of loose pieces in old barrels and inside cars... I had a stack of hubcaps six feet tall and put together a set of five '58 Caddy caps that I found every one in a different place.
    The '56 Cad caps would be good for if you were running wide wheels on the rear and wanted a deeper dished look with them, and it would be easy to change the center for a chrome bullet - you could even rig it so a bolt holds them on to one of those things GM used for their phony wire wheel caps in the 1980s/1990s - but that's about all I think.
  6. liljonny
    liljonny
    from menifee,ca
    They look like 60 or 61. I had a pair or 55 caddy caps on my 53 buick( album). Gotta watch out for those caddy caps cuz they do run deep and unless u have a caddy rim... it can be a no go.
  7. doc's
    doc's
    The '56 Caddy caps are what I used to run on my 6-lug GM 15x8 truck rally wheels.....grind the rear rib, pop out the center & you have a neat trim ring.
