Projects Armadillo's 34 PU
Discussion in 'Traditional Hot Rods' started by ELpolacko, Oct 8, 2013.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    I likem with no fenders...
    kidcampbell71 likes this.
  2. drmrman
    drmrman
    from new Jersey
    Larry that stock height cab with those color combos looks incredible! Really nice truck.
  3. AHotRod
    AHotRod
    ....oh yeah brother Larry :)
  4. bondolero
    bondolero
    hope you dont chop it bud
    Nope, want the head room and prefer the stock body look.
  5. 50Fraud
    50Fraud
    Wise decision.
  6. Ironmonger
    Ironmonger
    Ok, I'm hooked. How do I subscribe to a thread?????
  7. river1
    river1
    Near the top of THIS page in the red line there is a ****on "thread tools" click it, then click subscribe
    later jim
  8. 50Fraud
    50Fraud
    If you post to a thread, you are automatically subscribed.
  9. Pewsplace
    Pewsplace
    Any progress photos?
  10. ELpolacko
    ELpolacko
    I have pictures, just been delinquent in posting.
    Sent from my **** Tracy Two-Way wrist radio.
  11. ELpolacko
    ELpolacko
    Been busy with another project in shop, non HAMB related, that has taken up too much of our time. But I have a new shop hand and he's taken on finishing up on Larry's PU.
    Dr Marvelus finished the front fender repairs and install the MAC'S running boards. The the first things "Cowboy" did was mount the bed, make the rear bed mounts and fit the rear fenders. Larry had another shop do some patching to them and they did a nice job, the problem was the welds were not planished and the fender shape was distorted bad enough that the fenders would not fit. I had Cowboy tune them up and fit them, beautiful now.
    Right now, I'm on to fitting a steering gear to the frame. I started with one of Larry's supplied F1 steering boxes, cut the flange off and welded on a new flange. I am going to fully rebuild this with new bushings etc. Then the angle I have it installed at is going to require a universal joint, but I'm going to build a sleeve that fits over the joint to look more factory. Having the joint in the middle will give a better angle to the steering wheel and more clearance for my brake and clutch pedals.
  12. Hahahahahaha His nickname is cowboy how perfect. The truck is looking awesome.
  13. How'd the running boards fit? The last set we got needed some extra stuff to finish 'em out.
  14. ELpolacko
    ELpolacko
    Not too bad. Needed a bit of adjustment and the outside corners welded.
  15. bonesy
    bonesy
    Truck looks perfect.
  16. bondolero
    bondolero
    Getting close to coming home ! Going to be fun to drive.
  17. Hotrodmyk
    Hotrodmyk
    I like it!!!!!
  18. bondolero
    bondolero
    Again, the coolest thing about this truck is it was all parts from all over the U.S. and mostly coming off the HAMB and Ford Barn. As you can tell, the only parts that came from the original grain truck were the cab, grille, and front apron. A true "parts" truck.
    IC has done a super job keeping it traditional.
  19. malibulvr
    malibulvr
    Your doing an amazing job on that truck! Love the look of it with the fenders. I'm always amazed at the precise work done by guys on the HAMB.
  20. bondolero
    bondolero
    Does anybody make a panel that will squeeze 4 gauges and a speedo into the original oval portion of the 34 dash ? Most are so large, you have to cut 1/3 of the dash out in the center to get them flat, and I will run a second gauge panel before I do that.
    thanks
  21. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^Wondering the same thing!^^^^^^^^^
  22. Check your PMs
  23. sololobo
    sololobo
    cl*** act all the way, AWESOME DUDE! ~sololobo~
  24. NealinCA
    NealinCA
    How did you weld the flange on? MIG, TIG? What filler?
    Thanks,
    Neal
  25. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Awesome looking truck. I really dig on that front spreader bar. What's it from?
  26. ELpolacko
    ELpolacko
    Neal, cleaned very well, pre-heat and MIG welded.
    I tried Nickle 99 but it cracked right away. Very pretty weld though except for the crack.
  27. ELpolacko
    ELpolacko
    Spreader bar is from the donor "Big" truck that the cab and front fenders came from.
  28. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Very cool!
  29. bondolero
    bondolero
    The guys found a 6000 lb grain ticket in the cab from a wheat silo in Minn. The owner was a state legislator and they used the truck up until 1968. I bought the truck and the broker took his hot stick after the the cab, hood, grille, and fenders. The rest came from donors here on the HAMB. The column drop and NOS mercury steering tube came from free bay.
  30. ELpolacko
    ELpolacko
    And here is the wrap up...
    Armadillo and Bondolero picked up the truck yesterday. I believe it is on hold until the 38 Chevy truck is done with final ***embly.
    So when I left off last I had to sort out the steering and brakes. The Ford F1 steering gear had the flange welded on but still needed to be rebuilt. We also put a universal joint in at the toe board to give a better angle on the steering wheel as well as plenty of room for the pedal sets.
    The pedals themselves presented a bit of grief. Some heat and reworking on the stock pedal arms and a new fabricated pivot box got things in line. I'll cut to the chase and just post pictures. I unfortunately didn't get all the shots I wanted.
    That's about it. Thank you for looking!
