arvin heater
Discussion in 'The Hokey Ass Message Board' started by guido`s 40, Feb 19, 2012.
  1. guido`s 40
    guido`s 40
    from nebraska
    where can I find a 12 volt motor for my arvin heater out of a 1940 gmc? I tried chevy`s of the 40`s and the one they have is too long
  2. 41PICUP
    41PICUP
    Try Sacramento Vintage Ford, Bob Drake or C&G Ford Parts.
    When I set mine up I used a voltage reducer.
  3. guido`s 40
    guido`s 40
    from nebraska
  4. silversink
    silversink
    I run a ceramic voltage drop on mine, been working good for 10 years. The rheostat type of heater switch is what I use, I just don't run it on high position.
  5. uncle buck
    uncle buck
    You might try looking at some engine cooling fan motors. Most are of a thin design and you might be able to adapt one.
  6. squirrel
    Used to be if you went to a real auto parts store, and looked in their air conditioning parts catalog (by Everco or Four Seasons or whatever) they have a list of universal blower motors, listed by size, shaft size, voltage, speed, direction of rotation, etc. Then you find one that will fit, and order it.
  7. guido`s 40
    guido`s 40
    from nebraska
    i`ll give that a try squirrl seems like anymore if the kid at the counter cant punch a newer make and model in the computer you`r screwed
  8. 48ford
    48ford
    Like squirrl said,
    Take it out ,and take it with you to the auto parts house and just match it up.
    Also heard of people using a fan out of a computer tower,they are 12 v too.
    Russ
  9. squirrel
    computer fan isn't gonna move much air compared to a heater blower
  10. Ned Ludd
    Ned Ludd
    You get some SERIOUS CPU fans these days.
  11. 49ratfink
    49ratfink
    just run it on 12 volts if the old motor still works. it will just run a little faster.
  12. uncle buck
    uncle buck
    Try taking a look at a NAPA Balkamp # 655-1022 . It has a short body length of 3.75" from the shaft to the tip of the motor.
  13. 41fastback
    41fastback
    Go to NAPA online and search for heater motors. They use to give dimensions.
