1952-59 Ford AS REQUESTED...Jeep Cherokee steering Box install
Discussion in 'Off Topic Hot Rods & Customs' started by shortshift, Mar 2, 2022.
  1. shortshift
    shortshift
    Picked up a 2000 Jeep Grand Cherokee box at wrecking yard. Made mounding plate after mocking everything up and was able to use a couple of the original holes in frame. The frame has to be notched to make room for the jeep box, but there is room. Just make sure there is a bit of space between box and upper A arm bolt. I decided to re-shape the Jeep pitman. Lots of heat and burry in sand so it cools slow.
    The Pitman small end diameter is to large, so i found an insert at a 4x4 site. That made it fit the tie rod. I know some guys used the original pitman and expanded the large end. If anyone wants more info, send me an email jimpeg1@hotmail.com and i can answer any questions...Jim
    small Steering box done.JPG small Steering box install (3).JPG small Steering box install (11).JPG small Steering box install (9).JPG small Steering box install (13).JPG small Steering box install (5).JPG small Steering box install (6).JPG
    ffr1222k, 56longroof, nosford and 3 others like this.
  2. frnkeore
    frnkeore
    Thank you, very much, shortshift.
    You included very good pictures and detail.
  3. Zax
    Zax
    If I remember correctly all the Jeep Cherokee series steering boxes interchange but the Grand Cherokees have a "Quicker" ratio than the standard Cherokee. I believe the first generation Grand Cherokees (ZJ) have the most desirable ratio for swapping into a car.
    Typically there are plenty of Cherokees to pick over at the junkyards. They sold a ton of them.
  4. shortshift
    shortshift
    I believe 1999-2002 Grand cherokee boxes are the same. I never looked at other jeep boxes, but the main thing was the distance to the pitman so it can swing under the frame. 2000 is what i used...Are Cherokee and Grand Cherokee the same??? I dont know. I really like my steering ratio and the 1 finger steering is a real plus for me..
    ffr1222k likes this.
  5. Keith Sweesy
    Keith Sweesy
    from Hope, Ar.
    Mine just a 99 Cherokee xj. Haven’t had time to do any digging on it yet.
